Redcat Racing Tornado Thread
#1051
CA
ok i have an odd problem[
]. i bought an hpi header a few months back and put it on my VX 16 engine. i was driving it around to day when the car got really loud so i took the body of and the screws holding the header to the engine where gone lucky i had spare but i put those on and they are gone now to[:'(] the thread on the engine is completly gone and wont hold the header do i need a new engine??????
#1052
IN
i thought the header only had threads, and the motor didnt.. anyways, r u using some thread lock stuff? that will keep them from falling out, pretty much all the stuff on the motor u want that on so they dont come lose.
#1053
If nothing else get some small nuts to put on the ends
#1054
Any ideas on why i melted a set of alloy clutch pads in two runs?
#1055
Sorry to bother you guys, but what is the teeth for 1st and 2nd gear on the stock steel clutch bell? If I don't mind doing the pull start, is it necessary to buy the roto start? Do you guys know of any carbon fiber parts for the tornado? if so where?
#1056
CA
To dark down in the shop or I would look but I think there 17/22 and keep the pull start if you like nothing wrong with that, in my case I have the roto start because I'm lazy[&:] as far as carbon fibor is concerned you will probably have to cut your own if you want it. Plastic is plenty strong on those buggies
#1057
Thanks, and where would I find some carbon fiber to cut out, if I so choose? Also, how many cc of oil do i put into the stock aluminum shocks?
#1058
CA
Someone said it could be found on e-bay. I don't know where to get it because I couldn't justify it as an expense for my race cars when I saw first hand it held no advantage. As for the shock they are all different...........if your not racing just pull the shock rod down all the way and fill the shock to a little more than a 1/4 of an inch from the top. seal it and wheel it. For racing there are to many formulas to go over , but what I gave you should get you by
#1059
awesome thanks, how about cheap aluminum arms and hubs? i can't seem to find any under $20
#1060
sorry for so many questions, but do you know any shock towers that will fit directly? (from companies other than redcat and himoto)
#1061
CA
Cheap aluminum parts? the least expensive parts that I've found are Redcat for aluminum and the aluminum towers are the cheapest aluminum part you can buy. If you do a little checking out there you will find that after market aluminum parts are a lot higher on other models than Redcat..........lower arms front or rear for a Revo or a Mammoth go from $35.00 to $100.00 +[
#1062
Hi all,
looking to buy a couple of these to compliment my Bonzers,
but can someone just confirm that I am looking at the right ones.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=230169454459
Is this the correct model ?
OH
Here's a tech question for my redcat tornado XL.. was running it today and all of a sudden i noticed no brakes! ok so stopped it and found that the brakes wont engage and neither will the rear drivetrain as the rears wont spin. the fronts are all good.. what can this be?
#1064
CA
grub screw at the transmission...........its the part the is attached to the transmission that drives the dog bone.........there is an allan screw in it that needs to be tightened[&o]
#1065
MI
is there a difference in glow plugs? can a glow plug go into any vehicle? does it have to be a certain glow plug to fit the tornado/shockwave
wats the difference between cold medium and hot? for the glow plug
o by the way. does any one know the part number for the glow plug redcat shockwave buggy??????
#1066
OH
ORIGINAL: rclynx
thats what i thought but i cant seem to figure out it goes back together.. if i just tighten the grub the screw goes in way too far. also the dogbone doesnt turn the brake disc either. any pics of what ur talking about with arrows would be greatly appreciated
#1067
OH
ORIGINAL: kegger420
ORIGINAL: rclynx
#1068
OH
ORIGINAL: rc_nooby
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCB26&P=ML]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCB26&P=ML[/link]
#1069
CA
Good I'm glad I just got here and read your post............some time when you tear it down to clean or fix something put blue lock tight on all the metal to metal screws[&o]good luck/ happy RC'en
#1070
I have the same question as the guys above.
Difference between Hot to Cold glow plugs
I know that Hot is for richer engines and the O.S. A3 is an exceptional glow plug.
I just see cold glow plugs are more expensive, so I am just wondering, Am I missing out on something good?
#1071
CA
Not missing out on anything with a cold plug in a small block engine. The reason for a hot plug in the smaller engine is because it's a small engine. A small engine won't hold the heat and in order for the glow plug to work properly it needs the heat. this is the rule for the small 1/10 truck and buggies..........On the other hand you get a lightning that your holding at 20 thousand + rpm when driving you need a medium plug,but thats because the R's are there to keep the heat.[sm=shades_smile.gif]
#1072
Thanks, you've been a lot of help. One more thing about glow plugs, Is it neccessary to get the expensive ones made out of platinum? supposivitly it lasts longer
#1073
Hey guys, I just noticed today that my steering bellcrank (the one connected to the servo) has cracked, I used CA glue to fix it, but I feel that in a turn it will break, so do you guys know of any aluminum ones that will fit in my tornado?
#1074
CA
I don't like the platinum, but not for any special reason (they are made for turbo) other than I would like to change out that oil soaked one every once and a while anyway. Try the Thunderbolt #3 Competition #115559 great plug for the VX's and I like #147024 SE004 SH Glow Plug - SH #4 Medium Temp for the .28 SH 3P[&o]
#1075
ORIGINAL: newdoughboy
i am pretty sure either redcat has or is getting them in aluminum as a hop up, maybe nick can chime in tomorrow about this.
