Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Redcat Racing Tornado Thread
Old 01-20-2008, 03:11 PM
  #1976
ehroof
Default RE: Redcat Racing Tornado Thread
either your local hobby shop, if your going online, i get all my stuff from clermontmotorsports.com or redcatracing.com
Old 01-20-2008, 04:46 PM
  #1977
sc2toplay
OS cvrx Blue 11j is that the motor for the tsunami
Old 01-20-2008, 04:55 PM
  #1978
ehroof
almost any 1/10 car but that will be a direct replacement for the tsunami or the smartech
Old 01-20-2008, 05:43 PM
  #1979
brandon32689
Hey eddie, I got those scres for the little turning thing and got all that back together and the avalanche is ready to go as soon as i get those bearings. I was just checking everything and when i turn the car on and the remote on the front wheels are kinda turned to the left. on that remote i go to the trim and try to change it but i am not really sure how? could you explain a little over this or will it be to hard. lol that remote does alot of confusing things to me.
Old 01-20-2008, 05:53 PM
  #1980
gokartingbob455
gokartingbob455's Avatar
hey is it just me or when the batteries in the car go bad does the engine run terribly? my batteries died when i was starting my tornado and the enigne ran extremely poorly when it started
Old 01-20-2008, 06:09 PM
  #1981
sc2toplay
what do you know about the orion .28 wasp......is it good motor ???is it easy to tune and fix
Old 01-20-2008, 06:11 PM
  #1982
sc2toplay
found one on craigs list for $30.....said he could never get it tunned
Old 01-20-2008, 08:52 PM
  #1983
ehroof
ORIGINAL: brandon32689
i will or you can give me a call and i will go over it on the phone with you, its easier with it in my hands, lol
Old 01-21-2008, 01:15 AM
  #1984
brandon32689
lol ok that sounds good man. i got to work tomorrow and all so if its kool with you i will call you sometime tomorrow about 6 or 7 in the evening my time. it is 12.15 now my time so i dont know what time it is your time. hope thats ok thanks lol i got it all back together and looking good just need that one part. and i found how to start it with the body on like you said thanks man
Old 01-21-2008, 01:27 AM
  #1985
westicles467
Kind of new to this hobby, so please have patience with me. My Tornado BB pro pull string does not coil back, I was wanting to kind of upgrade the engine and other accessories. Question is, should I just stick with the factory eng. and buy a new pull start lever or go ahead and upgrade the stock eng? If I do upgrade the eng. do I need to switch out the trans and etc..? Basically I need some recommendations, they would be greatly appreciated.
Old 01-21-2008, 01:35 AM
  #1986
ehroof
good bro, its an hour later here, i am going to bed now so tomorrow should be good, if i dont pick up, just leave me a voice mail and i will call you back.
Old 01-21-2008, 01:38 AM
  #1987
ehroof
ORIGINAL: westicles467
you can upgrade to an os cvrx .18, its a killer engine and a direct bolt on, just have to swap the clutch setup and motor mounts from the old engine, the trans stays the same: http://www.clermontmotorsports.com/s...lue-11j/Detail
you can trade your engine in to redcat and get the sh.18, more powerful than your stock engine, also a direct fit like the os engine but if you use the engine replacement program, you get it 1/2 off, so it will be less than $50, i have it in my volcano and i am very happy with it: http://www.redcatracing.com/itemdeta...tno=sh18engine
Old 01-21-2008, 08:48 AM
  #1988
rc rock
rc rock's Avatar
just ran my tornado bb for the first time after break in and i have a few questions:
1) anyone know the engine mount skrews size (the ones underneath the car)? will any skrew work(i'm geting seriously close to striping 2 of them)
2)after just a minor crash the dogbones fell out of place, no prob just put them back on but there was a oil or something on the lower a arm that crashed what do you think it is?
3)how do you know which gear your car is in? i think it stays in second..any ideas on how to fix it
thx a lot!!!
Old 01-21-2008, 09:03 AM
  #1989
ehroof
ORIGINAL: rc rock
thx a lot!!!
1. not off hand, sorry
2. put a small sliver of fuel tubing in the drive cups that hold the dogbone, make sure there is a little play still, this will stop the dogbone from falling out again. Check and see if your shock is leaking, that could be the oil on the a arm.
3. If the rpms are low on take off and you have no real low end power your probably stuck in 2nd gear. There is a grub screw on the 2 speed shifter on the trans, 1 of them is to keep the shifter on the trans shaft, the other adjusts shifting time, clockwise makes it shift at higher rpm's and counterclockwise makes it shift at lower rpm's.
Old 01-21-2008, 10:27 AM
  #1990
rc rock
rc rock's Avatar
will this work instead of locktite?
ritelok threadlocker
Typical Use: Nutlock. Medium strength, general purpose threadlocker.
Color: Blue
Gap Fill: .005" .1mm
Torque Break/Prevail(in lbs) M10 Nuts & Bolts: 100-200/30-60 17/5 Nm
Temperature Range: -65°F to 300°F (-54°C to 150°C)
Fixture Time: 10-15 Minutes
Full Cure: 24 Hrs.
Old 01-21-2008, 11:33 AM
  #1991
newdoughboy
it looks perfect
Old 01-21-2008, 11:36 AM
  #1992
sc2toplay
where can i get some 89.5mm dogbones
  #1993
p3t3v3x53
just be carful on the offset of the rim cause i have the same car and i put buggy tires on it and they rubbed a little and it blew out my rear diff
Old 01-21-2008, 02:45 PM
  #1994
ehroof
ORIGINAL: sc2toplay
what part number?
Old 01-21-2008, 02:55 PM
  #1995
dominicevans
I ordered the wrong dog bones...these seem to be too short
Old 01-21-2008, 05:10 PM
  #1996
TNIGS
today i was looking at my car a i noticed that the rear wheels were toed in alot and the front wheels were toed out a bit. so i made the rear wheels straight and toed the front one's in a bit b/c i heard it made the car handle better. now i cant controll the car at all. i turn when i go fast and the thing did 15 cartwheels down the road. should the rear wheels be toed in??? one thing for sure, i am very impressed of how much abuse this thing takes without braking.
Old 01-21-2008, 05:12 PM
  #1997
fantsay09
hi,
just picked up a tornado pro.
i changed the clutchbell and put the hpi one on and the hpi gears. (there both purple)
and i changed the clutch spring.
but i tried to put the purle and gold gears on but they wouldnt mesh wll with the stock spur gears.
even with both purle gears on, its still not a perfect fit???
what should or do i have to change the tranny gears???
anything else i should look after on this car before i bring it out for a tough bashing session :0)
thanks a lot.
Old 01-21-2008, 08:31 PM
  #1998
sc2toplay
89.5mm dogbone part# 08029
Old 01-21-2008, 08:38 PM
  #1999
ehroof
http://www.clermontmotorsports.com/s...ft-83mm/Detail
Old 01-21-2008, 10:00 PM
  #2000
p3t3v3x53
yeah thats how mine is and i can turn at full speed and just slide. i think the rear is toed in just to keep the back from wondering around. and idk y the front is toed out because the traxxas trucks are suppose to be 0 degrees in the front and a few degrees in on the back.
