Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Redcat Racing Tornado Thread
Reply
Old 03-09-2008, 08:55 PM
  #2451
need2drag
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Redcat Racing Tornado Thread
Does anyone know the part # for the front dogbones (diff to wheel) for the tornado?
need2drag is offline
Old 03-09-2008, 10:31 PM
  #2452
Hibityhupla!
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: need2drag
I think it's either 06061 or 06022
Hibityhupla! is offline
Old 03-09-2008, 10:39 PM
  #2453
Hibityhupla!
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: k3viz
hi can someone tell me if the 08064 and 08065 will fit on the tornado?
its the spacer for the volcano wheels it would make my tornado wider hope it fits
You could try this too.. TLT, Hi-Lift, Wheely King 3/4" 12-12mm Wheel Spacers Found them on ebay. I use them on a couple cars with no problems but they don't see air-time so I don't know how strong they are.
Old 03-10-2008, 06:17 PM
  #2454
Hibityhupla!
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What's the best engine out there that still has a pull or roto start? I notice that once you hit a certain level they all go starter box only. Why is that? Do they make a bigger flywheel so we can use them? I kinda want to try the OS .21TM. It says it is a direct swap for the trx3.3. If that's true it should be no problem to drop in. The hardest part about dropping the 3.3 in was just changing the throttle linkage. Any thoughts on engines? Looking for something better then the os 18tz-tx (1.8hp 3000-34000rpms) more horse and rpms. I keep coming back the the Os speed 12tz spec2 (1.7hp 3000-45000rpm) but it's one of those that you need a starter box.
Old 03-10-2008, 09:16 PM
  #2455
jumpanddrop
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Hibityhupla!
what car is this for. if its for a tornado the os.tz 18 its way enof power. its acualy to much.
jumpanddrop is offline
Old 03-11-2008, 12:18 AM
  #2456
Hibityhupla!
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
not exactly.. I'm planning on changing my gearing. Already have the redcat lightning transmission and a 18t/23t bell. Now I'm going to jump up to 23t/28t bell. My original second would be my new first gear. In my tornado bb with the os 18cv-rx and that gearing I can pull 55mph and the cv-rx is only good to around 33,000rpms. Already have a 18tz-tx but compared to the 45,000rpms the 12tz can pull it looks slow. At least on paper..lol The only reason I'm thinking about the .21tm is the 1000 extra rpms and it would just look "mean". The only other 1/10 I know of with a real big block was the schumacher fusion and from what I've heard it's one "bad-???" car. Everything I can modify for speed on the bb will work with my on-road cars(same set-up) and visa-versa. So yes, this is for a car but it could all be done to a tornado easy enough.
Old 03-11-2008, 12:28 AM
  #2457
jumpanddrop
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
dude that would be soooo fast. u deffinatly would blow some diff's. it would be fun tho. i think go with the tz.18 b/c it wont need as much modding as a .21 would.
Old 03-11-2008, 12:41 AM
  #2458
Hibityhupla!
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That os .21tm is supposed to be a direct swap for a trx3.3 and I've put one of those in a car that's almost identical. On that one the only problem was changing the throttle linkage. So it should be easy. I'll stick with the 18tz at least until I'm done playing rocket car..lol After that I'll start rebuilding it again....
Old 03-11-2008, 04:17 PM
  #2459
k3viz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi can you tell me what is the maximum temp i can go on my tornado without frying my engine and what is the best fuel fur it can i run with 30%/12%oil is that good fuel
k3viz is offline
Old 03-11-2008, 04:24 PM
  #2460
pede_187
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i'd use 20% fuel.
pede_187 is offline
Old 03-11-2008, 04:35 PM
  #2461
k3viz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
whats wrong with 30%
becaus the hobby shop is closing and they have only 30% thats what i bought
k3viz is offline
Old 03-11-2008, 04:38 PM
  #2462
pede_187
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
your engine should last longer
pede_187 is offline
Old 03-11-2008, 05:28 PM
  #2463
k3viz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok thanks
k3viz is offline
Old 03-11-2008, 06:06 PM
  #2464
Hibityhupla!
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The higher the % nitro the hotter it runs but the glow plug plays a roll in that too. If that's all you have try to get the os #8 glow plugs. They are a medium heat. It might help.. DO NOT let the engine get over 300F. Easy way is with water or even spit. Just put some on the head and if it sizzles your too hot. It should just evaporate.
Old 03-12-2008, 03:37 PM
  #2465
k3viz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how hot woult you set the temp fail safe at 270?
k3viz is offline
Old 03-12-2008, 06:53 PM
  #2466
Hibityhupla!
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
couldn't really tell you... Never used one.. Sounds good though..lol
Anyone know of a back roto-start backplate that will fit the OS 18tz-tx? Bought one on ebay that said it would fit but it's for the 18tm not tz.. The tz has the two screws in the normal spot on the usual exhaust side of the engine and one in the center of the side of the engine that faces the chassis. Any ideas? Would it stay put with only screws on one side? Doesn't seem like a good idea....
Old 03-13-2008, 02:31 PM
  #2467
gokartingbob455
gokartingbob455's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey guys, i just went bashing in the snow and i cleaned my car up and then when i was getting ready to go back outside i turned everything on and i couldnt get more thatn maybe 14 feet away from it until the servos went all screwy and then they wouldnt move. my dad said it might be the crystal from getting wet. i dunno. please help, i want to go fast again! [sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=crying.gif][sm=cry_smile.gif][sm=crying.gif]
gokartingbob455 is offline
Old 03-13-2008, 02:33 PM
  #2468
Redcat Nick
Redcat Nick's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sounds like you got the receiver wet. let it dry out really good. then to test it turn your car on but don't start it and walk about 100ft away and make sure that everything still works.
Redcat Nick is offline
Old 03-13-2008, 02:43 PM
  #2469
gokartingbob455
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
did that but it couldnt hurt to do it again......hey could i use a hair dryer?
Old 03-13-2008, 03:07 PM
  #2470
Redcat Nick
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would just let it sit over night let it sit some where warm for awhile
Old 03-13-2008, 10:41 PM
  #2471
smokeout42o
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: ehroof
here you go bro,
rustler rear rims: http://www2.towerhobbies.com/cgi-bin...p?&I=LXJJ86&P=
pro line hole shot tires: http://www2.towerhobbies.com/cgi-bin...?&I=LXFHL9&P=0
ehroof .....so are these a direct fit for the tornado bb??? and also i have a tornado bb...what all do i need to get to make it a single speed??
smokeout42o is offline
Old 03-13-2008, 10:47 PM
  #2472
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yes, direct fit and you need 05126 and 02107
ehroof is offline
Old 03-14-2008, 12:54 PM
  #2473
Lordmik
Lordmik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, quick question. Part number 02040 Spur gear 44t. Some websites, including redcatracing.com, list this as for a two speed. Some give no description other than 44t gear. I counted the teeth on mine and it's 44t. But it's a single speed. Is this the right gear? I just want to make sure before I order.
thanks
Michael
Lordmik is offline
Old 03-14-2008, 01:04 PM
  #2474
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mike you want 05112 bro that other one is for the 2 speed
ehroof is offline
Old 03-14-2008, 01:17 PM
  #2475
Lordmik
Lordmik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well shoot. I thought I was going in the right direction. LoL Ok, do I have the right part number for the clutchbell 02107? And the teflon shoes with spring 02048? LoL
Thanks so much ehroof.
Michael
Lordmik is offline
Contact Us Archive Advertising Cookie Policy
