Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Redcat Racing Tsunami Thread
Old 02-12-2008, 07:47 PM
  #676
eminentguitar
Default RE: Redcat Racing Tsunami Thread
thats strange the flywheel on mine is a half an inch thick and the duratrax one looks allot thinner. can you give me the link to that thread please
Old 02-12-2008, 07:59 PM
  #677
ehroof
lol, i dont know where it is, its somewhere here, lol
its heading is something like compatible parts
Old 02-15-2008, 11:16 AM
  #678
eminentguitar
are gpm parts good?
Old 02-15-2008, 01:09 PM
  #679
ehroof
do you mean rpm?
Old 02-15-2008, 01:50 PM
  #680
KeithjV
GPM makes aluminum parts. They are pretty good from what Ive seen of them. I have one of their aluminum transmission cases for my savage. Its made pretty nice.
Old 02-15-2008, 03:40 PM
  #681
eminentguitar
cool I found some gpm steal cvd's that I can make work with my tsunami
Old 02-15-2008, 06:11 PM
  #682
ehroof
lol, in small case letters i didnt realize what it was, i have some GPM parts on my hpi mt.
Old 02-15-2008, 07:34 PM
  #683
eminentguitar
Do you know if the balls are the same size around on the mt2 dog bones as the tsunami bones?
Old 02-15-2008, 07:36 PM
  #684
ehroof
i have the cvd's bro but i would think they are close i just dont know if they are the same length.
Old 02-15-2008, 07:42 PM
  #685
eminentguitar
length is not an issue man im going to post a few pics on how to lengthen and strengthen your bones as soon as I can get my camera working.
Old 02-15-2008, 07:48 PM
  #686
ehroof
let the secret out of the bag bro
Old 02-15-2008, 07:49 PM
  #687
eminentguitar
or shorten them it works well and costs 5 bucks to do as many as you want just about
Old 02-15-2008, 08:42 PM
  #688
eminentguitar
Well no pics but ill just explain it as best as i can.
You have to grab the ends as hard as you can and pull. lol kidding
things you need - a barrel or roll pin kit with assorted sizes usually from any hardware store. (the little pins that are hallow and have a cut along the length of them)
-SILVER solder NOT LEAD OR TIN!!!!! silver solder is very strong and sticks to BARE steal very well.
You have to cut the dogbone in half and remove as much length as you need. If you have to make them 6mm shorter take 3mm off of each piece.(If you want them longer dont remove anything)
Find a barrel pin that you can barely force over the shaft of the dog bone. The tighter it is the better, it helps keep them straight.
Now you have to remove all of the black coating off of the pin and dog bones(even the inside of the pin, not fun i'm going to let you guys find a good way to do that because I still have trouble lol) I use 220 grit sand paper.
Force the dogbone halfs into the barrel pin(you may need a hammer just dont bend them) make sure you dont go to far its hard to get them out of the pin trust mel after you get the bone in the pin make sure the length is what you need by installing the bone back into the car or truck and making sure you still have play between the ends of the dog bone and you cups.
If everything looks good now your ready to solder them up. I welded mine with a MIG welder. I dont recommend it as it is really easy to warp them.
I would give you instructions on how to solder them but there are many types of silver solder some have flux and some dont. Just make sure if you get solder that does not have a flux core you have to buy the right flux for that solder.
You will need a propane torch for silver solder.
I hope this helps you guys out. I have had many challenges building this hotrod tsunami of mine
its got parts from just about anything you can think of on it.
Just pm me if you have any questions.
Old 02-15-2008, 08:47 PM
  #689
eminentguitar
If you have a gap in between your dogbone ends inside the pin make sure you fill it up with solder. Im going to post a picture sometim
Old 02-15-2008, 08:51 PM
  #690
Macanan
Macanan's Avatar
Your talking about useing spring pins right, these here ?
http://www.instockfasteners.com/Sear...lnk~1/search~2
thats a very good ideal you got there
Old 02-15-2008, 08:53 PM
  #691
eminentguitar
yup im just taking a picture of one now
Old 02-15-2008, 08:54 PM
  #692
eminentguitar
if you put the volcano stubs in a tsunami you have to lengthen the bones thats why I thought of doing this
Old 02-15-2008, 09:04 PM
  #693
eminentguitar
here are some pics
ID:	879613   Click image for larger version
ID:	879614   Click image for larger version
ID:	879615   Click image for larger version
Old 02-15-2008, 09:10 PM
  #694
eminentguitar
If you want a stronger dogbone dont weld them, use the solder(this is hardened steal and heat affects its strength). You can also use the barrel pins to cover the entire dogbone just make sure you have enough clearance for it
Old 02-15-2008, 09:16 PM
  #695
ehroof
nice information there bro, i give you an A+
Old 02-15-2008, 09:18 PM
  #696
eminentguitar
Thanks ehroof I just hope it helps someone get out of a crappy situation.
Old 02-15-2008, 10:55 PM
  #697
snowcruiser_91
so, i visit this forum on my phone for the most part, making it hard to search for things in a large thread: so im sorry if this has been posted\answerd already.....i have an AMAX model cheetah, which i was told is basically a redcat tsunami regulalr...i got it used, already broken in, and when i got it, i got it to run, but very rich, and it wouldnt stay still on idle, it would wanna drive off...so i tried to adjust her, i know where the high speed needle, low speed needle, and idlele set are...i adjusted them according to a thread on here; high speed-4 turns out or so, low speed-the screw head flesh with the casing its in, but my idle set screw doesnt seem to o anywhere when i turn it, i can turn it infinately in either direction with out it going in or out or changing anything...now, even when primed, glow starter charged and on, i cant get it to start...? any suggestions?
Old 02-15-2008, 11:14 PM
  #698
ehroof
4 out is too rich on the high needle, try starting it off the ground, if its starts and stalls when you put it on the ground, the clutch spring is broken and needs to be replaced
Old 02-15-2008, 11:27 PM
  #699
snowcruiser_91
thanks 4 the quick reply ehroof...! ill try that probably tomorrow, but what about the idle set screw...?
Old 02-17-2008, 12:36 AM
  #700
KeithjV
ORIGINAL: ehroof
Got any pics of your MT? Im in the process of hopping up a used MT2 I picked up.
