Redcat Racing Tsunami Thread
#1328
RE: Redcat Racing Tsunami Thread
ORIGINAL: firstrc
Yup.
Yup.
Hey first R/C, i just orderd a couple of tsunami epx, does it come with 8 shocks? our does it come with 4 shocks? There were all out of the volcano so i got the tsunamis.
I rather it come with 8 haha, what kind of suspension adjustments did you do?
#1329
Well after 5 gallons of nitro and way too much abuse I finally blew my diff in the rear. So now I get to put the hpi mt2 18ss hardened diffs in it I just hope there going to be stronger then the redcat ones. The diff was in great shape till I put the 52 tooth spur gear in it but its so much more fun to drive with the lower gears.
#1330
Ok I just took my diff apart and noticed that the crown and pinnion are in reasonably good shape so what the heck is going on here the spider gears are perfect. Could it just be the bearings are worn out enough to cause enough play to make the gears skip? I have to say that these redcat diffs are way stronger then I thought they were going to be.
#1331
ORIGINAL: eminentguitar
How are your wheel hexes and the inside hub on the rim? I thought my diff was blown, but i found out the wheel hex was rounded off from the torque, and the inside of the rim were it holds the hex was rounded a little. Also make sure all the C clips are in the diff.
#1333
ORIGINAL: islandturbos
ORIGINAL: firstrc
Yup.
Yup.
It didnt take long to figure out that they had to go. I put the alum uprgade shocks on it (8). My adjustments were just trial and error. Right now they are wound down about .5 inch from the top. Slightly stiffer in the rear to keep the front end down.
#1334
The tmaxx big bore shocks are killer now it stays on the ground more I used to have a problem with it bouncing everywhere. The only thing is you have to use the plastic spacers on them for the spring adjustment
Does anyone know of the strongest 1/10 scale diffs out there???? Im up for any chalange mods are what I do best I just dont want to have to be rebuilding my diffs every ten minutes after I put that tz in there
#1335
CA
I've heard that the MT2 aftermarket metal gear aluminum housing are some of the strongest, but I see they haven't given you much responce. I do know that one of my customers bought about 3 differentials from me after the purchase of an .18TZ and never could get the differentials to stay together..................there aren't many out there that can hold up under that horse power. Some of the 2 wheel drives will though to bad theres no money in the ST models anymore, if there was I'm sure Darin would be right there
#1336
Well I was thinking of putting the mt2 diff in there because I have 5 of them and what do you mean by the ST modles? what kind of 2wd diffs are strong?
#1339
Well I just about have the hpi mt2 rear diff and arms with the hpi cvd's installed into my tsunami hope there going to be good the only thing is the shocks I have are way toooooo short
#1340
Ok so far I have hed to lengthen the wheelbase about half an inch just so I had fresh material to drill new holes for the diff mount in the chassis. If you want to do this without lengthening the wheelbase you can use the redcat diff mount(not sure of the exact name) bulkhead maybe? and the redcat sealed diff case the hpi gears fit into the case so iv been told lol. so I have to lengthen the drive shaft now so far so good. ill take some pics soon
#1342
CA
ORIGINAL: peewee146
i have a tsunami and the take off is so slow how do i meke it have a faster take off
#1344
AB, CANADA
Have you played with your lsn you may be flooding it (running too rich)or not giving enough fuel (Running too lean). Or you may have an air leak check your fuel lines and anything else that may be loose on the engine. And after breakin did you change the glow plug. There are lots of other things but thats where I'd start myself.
#1346
AB, CANADA
I just want to confirm that you have no low end speed? Is that your problem? If so is youyr high end speed okay? The guys here need to know more about your problem to diagnose it.
#1349
AB, CANADA
I don't know alot about the 2 speed tranny but I do know if that little grub screw is turned in too tight it will start in second gear. Correct me if I'm wrong guys I've never had to fix a 2 speed,all my trucks are single. Heres a post with pics about a 2 speed try this next http://www.rcuniverse.com/forum/m_4314984/tm.htm
