Redcat Racing Tsunami Thread
#1501
RE: Redcat Racing Tsunami Thread
ORIGINAL: KeithjV
Does anyone know the stock shift point setting? How many turns out it should be? My truck doesnt seem to be shifting so I want to reset it and go from there
Just remember that out with the screw means it shifts sooner. I noticed that some people think its the other way around.
#1502
NY
Thanks eminent. I may have to take it apart and see if something is stuck. I had the screw almost all the way out and it didnt seem like it was shifting. You might be right there might be some dirt stuck in the clutch.
#1503
Might be man. Or another thing, its rare but there is a pin on the smaller spur gear that might pe worn off. Its that pin that the small metal piece catches when you get the rpm's to the point of it shifting. I just sold a bunch of redcat stuff on ebay for just about nothing. Maybe next time ill let everyone here know im getting rid of stuff.
#1506
NY
Im not actually sure at the moment. Im going to change the clutch to the 2 shoe type as soon as I get a new pilot shaft. Keep me in mind if you are looking to sell any of the parts though.
#1507
NY
eminent I know you told me which pilot shaft you used on your engine but I cant find the message. Was it this one?
http://www3.towerhobbies.com/cgi-bin...?&I=LXM721&P=M
#1509
ON, CANADA
ORIGINAL: gearguy70
well, ran it again, and the needle didn't move, I'll the o-rings on and see if I can find new ones, just in case, and no, there isn't any fuel leaking anywhere, this thing is sealed.
I had the same problem on my volcano, the needle was constantly leaning itself out while I was driving. Soon enough it started to leak fuel out of the hsn. The O-ring looked brand new so I just put a slightly larger o-ring on it (possibly the old one was worn out) It has been perfect ever since. If you don't have a LHS a carburator shop is your best bet.
Adam
#1511
NY
Thanks eminent. I'm going to have to replace the CB as well. I had the truck out today and it still isnt shifting right. I finally got it to shift but as soon as it does the power dies right off. Not sure what thats about. I was checking the truck over and I noticed the CB is starting to crack and get out of shape. I think Im going to put the HPI CB on it. Did you change the axles on yours to give it a wider stance? I know some one on here listed the parts needed. I just have to find the message again.
#1512
Yeah man put the hpi bell on its way better. The parts you talking about are they the volcane wide hex hubs? There a great sollid upgrade man well worth it. The only thing is then your not able to use the hpi mt2 parts on your tsunami because the balls are smaller on the redcat parts. What I did is made my tsunami 2wd and have my mt2 4wd so I use the volcano sv pro stubs and aluminum wide hexs on the front and the hpi gear on the back. Its a nice setup. But honestly man what I would do (from lots of wasted money learning) Just put the hpi mt2 arms and cvd's in. they make make yout stance wider then with the volcano sv stubs on stock tsunami arms.
#1513
NY
The problem Im having is that I used the HPI hubs that came with the wheels to try to offset the wheels a little but I dont have enough thread on the axle for the nut to stay on. I figure the volcano axles should give me enough thread for it to work out.
Have you ever seen the CB crack before? What size clutch springs did you put on your truck?
#1514
Well man If you get the volcano stubs then just get the aluminum sexes there half an inch long and work great. Yeah i have seen cb's do some really crazy things. The one my buddy had flew appart in his on road picco 12 or 15 i think it was. It made a big mess lol.
#1516
lol count yours..... Im not to sure its 17/22 i think no promiss tho lol. Just get the hpi bell man there way better.......although some people say the new steel redcat bell is not bad.
#1519
hey, I have a tsunami epx i want to upgrade the motor by getting a brushless system, i am looking at the castle creations any suggestions and also would i have to by a new radio if i got the new system?
thanks
thanks
#1520
thanks
thanks
#1521
hey guys, about that gall bladder in the exhaust, I know the car can run with out it, but, are there any adjustments necesary on the carb in order to run the car smoothly? or can I just remove it and drive it with the normal settings it has now?
#1522
hey, i was outside playing with my tsunami epx today and i had only been runing it for 5 mins when it completely stopped the servo for the steering works but the motor doesnt the light on the spped control doent come on or beep when i push th throttle is my speed control bad do i need to get a new one? thanks
#1523
NY
gearguy, if you take the bladder our you will definitely have to adjust your needles. Im not positive, but I think you will have to richen the HSN. I could have it backwards though, so its trial and error time.
foust, make sure the batteries are fully charged. Check the esc wires going to the receiver, make sure it didnt come loose. If you have access to another receiver I would try that too. If it still doesnt work it could be the esc. Good luck
