Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Redcat Racing Tsunami Thread
Reply
Old 08-05-2008, 11:45 PM
  #1826
uhoo_01
uhoo_01's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Redcat Racing Tsunami Thread
planing to put a few more break in tanks through the axial to night , it sucks tho cos i finish work at 6 and its winter here so its getting dark at 6 . taking it to my old mans factory and run it under lights .
uhoo_01 is offline
Old 08-06-2008, 03:40 AM
  #1827
uhoo_01
uhoo_01's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well just put 6 tanks through it , pretty hard break in for it and all drivetrain held up ace's . i think the diff and all gears will take the bb no prob AT ALL . i would have put more through it but i had the slightest graze against a wall and broke another front c-hub , i swear thos things are made of glass lol .......
uhoo_01 is offline
Old 08-06-2008, 08:00 PM
  #1828
eminentguitar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They are man I swear I hit a bee and broke one lol kidding
eminentguitar is offline
Old 08-06-2008, 08:07 PM
  #1829
uhoo_01
uhoo_01's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
aaaaaaaaaaaahahahahaha lmao
uhoo_01 is offline
Old 08-06-2008, 08:08 PM
  #1830
uhoo_01
uhoo_01's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
got a set of jato wheelie bars coming im gunna need em heheheheheheheh:P
uhoo_01 is offline
Old 08-06-2008, 08:41 PM
  #1831
retrosoul
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i just finnished to tanks and i noticed my truck doesnt roll free. i checked the brake and its not engaged when i roll it it makes a clicking sound near the motor and it will hang on the click so when i roll it. it sounds like this click.....click......click.......click i checked the mesh its good any ideas before i rip it apart? i was thinking maybe clutch spring but im not expert.
retrosoul is offline
Old 08-06-2008, 09:03 PM
  #1832
Swamp3r
Swamp3r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll guess clutch too
Swamp3r is offline
Old 08-06-2008, 09:07 PM
  #1833
retrosoul
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wonder if i could just make a new bend in the spring i can tell you this the clutch bell is like 3 different colors
Old 08-06-2008, 09:14 PM
  #1834
KeithjV
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
more then likely the clutch spring broke. It its just the end you can easily put a new bend on it. I did it with mine and it lasted for a while before I had to do it again. After the second time it broke I replaced it. You'll have to pull the cb to find out for sure though.
KeithjV is offline
Old 08-07-2008, 09:22 PM
  #1835
retrosoul
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok i think i found the click and hang up it is coming from the brake. the metal disk flops around i can move it back n forth im not sure if this is normal i think it should be tight on the drive shaft.
Old 08-07-2008, 09:55 PM
  #1836
retrosoul
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok nevermind nothing wrong with the brakes its defanetly the rear drive shaft. hmm how do i xplain it. if you look at the drive shaft coupling on the transmision side the pins that go into the slots to stop the shaft from spinning in the coupling are warn and one of the pins actually slips out of the slot and drops inside the coupling the pin on the other side stays in place im not sure on what part should changed either way it looks like a ***** to change i can get the set screw loose on the front drive shaft ill try some pb blaster on it anyways i can probaly still drive it till it breaks completly while the replacment parts are on the way it doesnt slip during driving i also noticed that the pins made groves on the inside of the coupling grove im sure this is normal wear and tear but ive only had the truck for like a month now
Old 08-07-2008, 10:25 PM
  #1837
retrosoul
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok by coupling i mean universal joint sorry about that
Old 08-08-2008, 01:10 AM
  #1838
eminentguitar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah man thats normal wear and tear they dont last long and when you try to get the set screws out try to heat them up a bit thay have lock tite on them and heat is what is used to break it free. I put the hpi mt2 drive cups on my tsunami because I was tired of them wearing out all the time. My brake disk does the same thing man sometimes it hangs up.
Old 08-08-2008, 06:08 PM
  #1839
KeithjV
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can also try adding an o-ring to the drive cup to take up some of the play in the dogbone
KeithjV is offline
Old 08-08-2008, 06:11 PM
  #1840
retrosoul
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
got a new air filter setup today from my lhs. its made by ofna its mutch larger not sure if it adds more power but it makes me happy looking at it also picked up some e-clips body clips and a quart of fuel. my lhs doesnt sell 20% by the gallon anymore only 33% and im sure 33% wouldnt be good for my tsunami.
Old 08-08-2008, 06:12 PM
  #1841
retrosoul
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
already an o-ring in it can i add 2 o-rings?
Old 08-08-2008, 06:14 PM
  #1842
KeithjV
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
retro you need to post some pictures with the new filter.
You could run the 33% but you might have to go to a cooler plug, it might cause the engine to run too hot.
KeithjV is offline
  #1843
retrosoul
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
where in ny keith?
Old 08-08-2008, 06:15 PM
  #1844
KeithjV
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sure as long as it doesnt push the end of the dogbone out of the cup.
Im on Long Island
KeithjV is offline
Old 08-08-2008, 06:43 PM
  #1845
retrosoul
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok heres some picture of the air filter and yes the throtle linkage does hit the filter im going to fabricate a small aluminum bracket for it.
Old 08-08-2008, 06:47 PM
  #1846
retrosoul
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i need a good tire and rim setup what can i get for direct fit?
Old 08-08-2008, 06:48 PM
  #1847
retrosoul
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
also 40 dollas is my budget on tires and rims less would be good.
  #1848
uhoo_01
uhoo_01's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey just wondering is it safe with the single speed redcat tranny to just run power to the rear wheels (2wd) by droping out the front shafts????? because iv bin breaking my engine in with only 2wd cos im waiting for a drive shaft . plus i was thinking any way 2wd will take a lil more load of the drive train because is will wheel spin more like it does and not hook up and break stuff .
uhoo_01 is offline
Old 08-08-2008, 06:51 PM
  #1849
uhoo_01
uhoo_01's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: retrosoul
the hpi racing Yoky geo-landers are a great tyre there only 2.2 but are super soft and sticky , i run them on the rear . but i think there $15 or so a pair so that only leaves $10 for rims .
uhoo_01 is offline
Old 08-08-2008, 06:52 PM
  #1850
eminentguitar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
uhoo I made mine 2wd and it was killer hard to controle and the rear diff didnt like it very much and your just going to add 2 times as much strain to the powertrain. Even if its spinning its still hard on things
Contact Us Archive Advertising Cookie Policy
