new to rc have no clue (4WD Tornado BB Buggie RC)
CO
RE: new to rc have no clue (4WD Tornado BB Buggie RC)
well the point is that the traxxas ones are better, but if you wanna go cheaper then those mip ones are a good choice.
SO GET ALL OF THIS AND THAT ALL???
LXCLR9 HPI Pinion Gear 22Tx12mm Nitro 2-Speed Nitro 3
1 4.79
LXUR89 MIP Replacement Clutch Springs T-Maxx
1 2.89
LXCLR2 HPI Clutch Bell 12mm 2-Speed Nitro 3
1 8.59
LXDHM0 HPI Aluminum Threaded Pinion Gear 17T Nitro 3
1 4.79
TRAC4147 Traxxas Clutch Shoes/Spring T-Maxx
1 4.79
1 2.89
1 8.59
1 4.79
#31
my stock clutch bell looks totally diff. It has two different levels of gears, and the threaded clutch i see you are suggesting only has one. is thear another gear to thread on after the large one ?? im confused??
#32
TX
Yes, there is two gears you thread on. you screw on the big gear then you screw on the smaller gear that gives you your two speed clutch bell.
#34
TX
I think you have to order the gears you want seperate from the clutch bell. The up side is that you can change gears with out having to get a new clutch bell, the down side is that the gears are aluminum and will probably wear out easier than steel.
#35
will i twork at all with just a traxxas clutch spring, cause it wont work at all witha stock spring and clutch bell, will it work with stock clutch bell and and shoes and a traxxas spring.
