Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Question
Old 02-25-2007, 09:35 PM
Andyde4
Default Question
Does adjusting the shock position on the shock tower give your more ground clearance?
Old 02-25-2007, 09:37 PM
AllAboutFunHobbies
AllAboutFunHobbies's Avatar
Default RE: Question
It can give you more or give you less. Depending on what position you move the shock to.
Old 02-25-2007, 09:39 PM
Andyde4
I've got them set to the highest
Old 02-25-2007, 09:47 PM
AllAboutFunHobbies
Bring them down to a lower point on the shock tower should give you a bit more clearance.
Old 02-26-2007, 12:04 AM
bluecaka69
bluecaka69's Avatar
you can also bend the tabs under the A Arm to help with clearance it has a kinda built in arm stop but if you bend it down you can raise the car a bit more
