Need help
Need help
So I purchased the Tornado BB pro and recieved it two days ago. I fully charged glow plug, fueled the car and put oil on the air filter. I put the glow plug in and pull on the starter and nothing. I have tryed about 30 times and nothing. I removed the glow plug and it's working perfectly. Anyone have any ideas? This car is straight out of the box and none of the settings have been tamperd with.
RE: Need help
did you prime it by putting finger over stinger (exhaust tip) and give it a few pulls you should see fuel move through the line and once it hits carb opening stop then put glow lighter on and give it a pull hope this helps
RE: Need help
That worked thanks! But now i have an idle problem. the car will run for about 10 seconds then shut off. If i get on the thorttle once i hit the brakes it dies. Any ideas?
