radio/controller/transmitter/wat ever u want to call it
MO
my bro drove my car and turned wheel too hard and it broke.i cant controll anything now, not even the throttle. i know i need to replace it but do i also have to replace the receiver if i replace the controller.im assuming so but i just need to know.well i got to go turkey scoutin so i might reply a little late .
thank you!
thank you!
RE: radio/controller/transmitter/wat ever u want to call it
dude thats crazy, it happened to me to lol, but u can get a controler from redcat then put the frequency chip from old to new and ur good to go.
MO
k thank you so much.i can fix all the stuff i need over spring break.do u know how much they cost?
MO
luckily i know how to fix it now or id kill him.and right before this he almost ran it into a tree.theres no way im letting him drive it again.
well its just all the radio gear then lol. when i swapped my controller i got better servo horns as well so it works well now.however the servo horns were not verry good at all(the stock).
CA
How high can you fly an airplane with that broken transmiter? [&:] now thats confused <---------------------me [sm=lol.gif]
MI
You basically have these components:
1. Transmitter (pistol grip controller)
2. Receiver (small box with antenna wire)
3. 2 Crystals - one for each the transmitter and the receiver
4. 2 Servos - one for the throttle/brake and one for the steering
6. Battery pack for the receiver
I recently snapped the wire off of my receiver box after soldering on a single piece of CAT-5 cable and will be likely ordering a whole new radio system so that I can get a better receiver, transmitter, and servos.
Depending upon what you broke, you can replace components individually, as in my case I could shop around and find a replacement 2 channel AM 27mhz receiver and use it as long as I removed the crystal from my stock one and installed it into the new one.
Hopefully that helps, here is a good upgrade for the entire system - http://www2.towerhobbies.com/cgi-bin...I=LXEDP1**&P=K
If you look under "Includes" you can see all of the components that you get.
MO
cant i just do wat fiecatsp80 said. its not like i run it all the time. the redcat one worked fine for me.
MI
I do believe if you open the controller/transmitter up, you can get the crystal out of it.
Hey, if you are interested I have a stock transmitter available ... I just purchased a Futaba 2PH transmitter, receiver, S3003 servo, and a JR Z650MG servo.
you dont need to open the transmitter up to get the crystal out, its in the front top of it, with a number like 27.125 on it, just pull that out and there is your crystal
thats it, you just have to make sure your new controller is the same mhz as your old one if you want to use the old crystals, like 27 or 75 mhz
MO
is the crystal the chip thing or under that.i might post a picture if i can.i mean chip as in the big green thing with metal electronic stuff on it.
