Tornado vs Curb! top Speed!
RE: Tornado vs Curb! top Speed!
Not bad looks like just a lower arm right? Try HIGHBANKS RC Shipping is only a $1.99 and he as all of the parts you need in stock and he has mini-t parts too and up grades .VTX parts. All of the redcat and Himoto parts and up grades too.
I did something similar to that. Except I forgot to put my antennae out. And went out of control and went flying at a high speed and smacked into the curb head on. At least my body shell didn't get messed up because I had it off for tuning adjustments. The front part of my chasis is bent up at a 45 degree angle. Here's some of the vital parts that I needed on the part list I just got done ording.
front bumper
chasis
dogbones for left wheel arm and front shaft
arm support pad
front differential casing
steering set A or servo saver whatever it is
and the upperdeck piece
so much for my first time with a nitro. And still a half a tank to run for the first fill. Then again I was originally going to run it in the mountains rather than my work. Glad I didn't. Zipp it full speed off a steep cliff and see a minature mushroom cloud.
front bumper
chasis
arm support pad
yall got lucky here is an accident from 2 wrecks back
http://www.rcuniverse.com/forum/m_54...tm.htm#5484879
Update! Been awake since 4 pm yesterday worked all night but couldnt sleep waitin on parts... Feelin a bit like Dr Frankenstein puttin this bad boy back together... Runs great but I left it 2 wd and it is only good for doughnuts right now in the dirt... Little thing will kick up some dirt! Have to give in to sleep now be up for work about 5pm... Next 2 days off will be a blast!
-ash
-ash
Question...........
Took a closer look at the car today after I was having trouble going straight. The glue on my rear tire is gone and the wheel is slipping causing the nascar like action..
What is a good glue to use to fix this?
Any type of prep for the wheel first?
-ash
-ash
WI
WI
yea that the same thing that happened to mine except a screw came out of my steering and it just turned like a dime it was freakin crazy crashed into a tree log because i got a trail throw a tree line and it just turned it was freakin crazy didnt expect it to do that lol
NY
The stupid batteries in my reciver died while I had the XP flying and I ended up hitting the foundation of my barn. Here are some pics from before and after the crash.
WI
http://www2.towerhobbies.com/cgi-bin...?&I=LXHLV3&P=7
OR
http://www2.towerhobbies.com/cgi-bin...&I=LXHUH6&P=ML
AND GET A HUMP PACK
http://www2.towerhobbies.com/cgi-bin...&I=LXHUJ3&P=ML
THIS WITH SAVE YOUR NITRO IF IT GETS OUT OF RANGE
OR
AND GET A HUMP PACK
MI
I definitely would get a failsafe, I got one now and it works great. Picked it up from www.allaboutfunhobbies.com
http://cgi.ebay.com/NIB-Mini-Failsaf...QQcmdZViewItem
he has alot of other good stuff too, no hump packs, i got 3 hump packs for $20 inclucing shipping from ebay, i havent found that deal again though, keep you eyes open
