gear drive clicking noise
WI
i have a problem with my truck the gear drive makes a clicking noise but the gears are like not stripped at all. and one of my front tires spins but the other doesnt all my grub screws are tite
RE: gear drive clicking noise
is the clicking coming from the front or rear end, if so its probably a gear inside the diff, if its from the center diff or trans it may be one of the small gears inside the trans, one of the ones you cant see
probably the pinion or the big gear, when you turn one wheel does the other move and not click when you hold it off the ground, if so its the pinion and big gear
Here is 02024 http://www.clermontmotorsports.com/s...t-*1SET/Detail
here is 02030 http://www.clermontmotorsports.com/s...r-*1PCS/Detail
MI
That sounds just like the issue I was having, I received my parts from Clermont the other day (thanks Dennis!) and I am running strong as ever again
MI
Not unless they sell Redcat parts.
You may be able to use HPI parts, but I am not sure of their fitment, feel free to test and let us know - http://www2.towerhobbies.com/cgi-bin...55&FVPROFIL=++
More info from HPI MT2;
