Removing "Gallbladder" From Stock Exhaust Pipe = Bad Idea?
RE: Removing "Gallbladder" From Stock Exhaust Pipe = Bad Idea?
LOL why would you want to remove it in the first place? There's only one way in finding out; Do it!! LOL go on see what happens. I'd be interested in the effect. But having said that my guess is that yes it will have an effect because that part is what makes it into a "2 chamber" tuned pipe.
WI
do these engines need backpressure?.. Has anyone ever removed it before?.. I dont want the be the guinea pig..lol.. I am almost posative I read somone talkin about that b4?
It looks Really restrictive.
you can run it without that, it still give enough pressure for fuel, it will be louder and have more top end, but low end may be worse. gaulbaladder, lol. imagine
BC, CANADA
ORIGINAL: XTM Will
I'm not sure about nitro, But all 2 stroke PETROLEUM engines need back pressure.
BC, CANADA
ORIGINAL: ehroof
i did it on my hpi, the stock plastic pipe, pretty much the same as the redcat, sounds better but low end not as good.
BC, CANADA
ORIGINAL: ehroof
WI
ORIGINAL: arlo1
realy? cool! have you tried? I want to try. I am just working the bugs out of my rc car dyno and I hope to test the stock pipe and the aluminum one and I will try removing the gaulblader as well soon!
ORIGINAL: ehroof
i would like to know the results of that. I have heard you talk about this dyno before. explain more. what did you use?. how did you do it?
BC, CANADA
here is a link to a quick video I put together. http://www.youtube.com/watch?v=XdjQ445WoJw I used too pieces of 88.5 mm od tubing I calculated out the inertia of the roller and then you enter that into the program that comes with the electronics kit. I purchesed this kit in hopes of building a motorcycle/car dyno in the future (you just have to figure out the inertia of the roller and enter in the specs like trigger wheel teath ect then you conect the electronics assembly to your P.C. it is still in progress but that is why I built the rc dyno first so I could learn from it. It costed me $65 to build pluss a little over $400 for the electronics. and $42 was the pillow block bearings.
BC, CANADA
Remember hp at the wheels is always lower then the engine it self and sometimes it can change alot going through the drivetrain. It realy dosent take much to hold these little engines back. The rpm is calculated It could be off a bit but if you listen to one of these engines and compare it to a hi end traxxas or something they dont compare. The traxxas sounds alot higher! I am hoping to change that I looked at the port timing in my .18 and the durations are stupid I realy think I could make this thing sing.
If you really after great performance I'd just go out a buy a top quality tuned pipe instead of chopping one up. Great for an experiement but I doubt you'll get much out of it. Its all well and good to have great top end but its not much point if you loose the bottom end at the same time. You probably need more bottom end than top when bashing anyway I reckon.
NJ
VERY nice.. Being an Engineer I can really appriciate the work you put into it.. Impressive..
ORIGINAL: arlo1
BC, CANADA
ORIGINAL: mozzzy_2000
CA
