I give up
MT
RE: I give up
well hurry up cause I already broke the pull start on the trugggy and the one on the buggy only has a few pulls left in her and i need them for the jump video im gonna try and sail my 1/16 over a 15 passenger ford club wagon haha I know good luck right but hey maybe ill break something them have reason not to drive it untill I get the parts to fix it
BC, CANADA
RE: I give up
I had the same problem and it was two things one was the fuel cap not sealing on the tank it was actualy built wrong so the pin for the hinge was to high holding the back of the cap to hight causing the oring to never seal no mater how new it was. And the second thing that caused it which is where the actual air bubbles came from was the out put was partialy pluged it just wasent drilled out properly from the factory I used a dentist pick and got it freed up but you can usaly tell by blowing through it and lots of fuel should shoot out with out bubbles it in. As for the gas cap you can presureize the tank by pluging the carb side and use a small amount of pressure at my shop we have a mitivac that you can pump small amounts of presure into the tank I used about 3-4 psi and sparayed soapy water around the tank to check it. good luck man. Hope this helps.
