engine cutting off problem
My Feedback: (8)
RE: engine cutting off problem
Since ur king of RC . Ok here is my problem when i steer to my right it stay to the right when it is centered. But if its in the air
it doesn't. And battery is not dead beside server has alot of juice. Can u help me? Here is a vid
http://s193.photobucket.com/albums/z...t=55b4040e.flv
Hope you don't get to dizzy
does it center when you drive? if so your ok, the stock servo's are not high torque, if it stays to one side when you turn and doesnt return to center when driving, you may have a sripped gear inside the servo or maybe your servo saver is set too loose.
My Feedback: (8)
http://s193.photobucket.com/albums/z...t=55b4040e.flv aye check it out. maybe i need to tight that servo saver a bit more so it wont flex what happend if i do that? and is it easy?
#34
CA
I've had 2 of them in the past year or so I had to replace because the plastic part of the servo saver would flex to much. One was on a Volcano and the other on a Tsunami[:-]
#35
My Feedback: (8)
u could also tight it up too. I grab a lockranch and locked it on the thread then i used a ranch to tight it up now it doesn't move that much. I hope i don't strip my gears on the servos. I was gonna use my airtronics but it doesn't fit well connector doesn't darn. But
its adjestible. I think I was messing with it last time. LOL i don't know!! I'm going to clean my car too sheesh i miss having it clean.
Now its a bit dirty and alot of crap underneath the gears. Black ****. weired
#38
i need to know how to set all of the screws on my tsunami. ijust got it given to me and it ran fine, but then i took it and cleaned it and now it does not run write, it will run for 2 sec and then die.
#40
jamesv, check this out, it will answer all your question: http://www.rcuniverse.com/forum/m_5399029/tm.htm
