newbie please help
newbie please help
hi guys i just had to replace the big throttle gear and i replaced the one way bearing and i put it all back together and started it up and gave it gas and car would not move is it possible that i can put the one way bearing in backwards or what could be the problem i have the new tornado bb thanks.
RE: newbie please help
when you say gears are not messed right what do you mean and when i tightened the clutch bell it does not want to spin freely either unless i back the screw up just a little bit also thanks
TN
When he says they arent meshed right he means the gears cant turn freely.Put a piece of paper in there and set the mesh so that when you pull that piece of paper out it doesn't tear it.
MI
ORIGINAL: one_bad_91stang
You will need to make sure that your washers are correct in there spacing. Thats the reason the clutch bell doesnt move freely. If you get it to move freely, follow the instructions that zack gave and you should be good to go.
