Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Redcat Monsoon Thread
Reply
Old 12-22-2007, 03:00 PM
  #201
motodude11
motodude11's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Redcats Monsoon Thread
just finished putting an integy aluminum roll bar from an lst2 on the monsson i'll post pics sometime tomarrow!!
motodude11 is offline
Old 12-22-2007, 09:25 PM
  #202
motodude11
motodude11's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here she is with the new integy roll bar!!!!!!
Josh
ID:	831770   Click image for larger version
ID:	831771   Click image for larger version
ID:	831772   Click image for larger version
Old 12-22-2007, 11:05 PM
  #203
vnmsgt
vnmsgt's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks nice! Have any close ups of how you mounted it? Also does the body fit on it?
vnmsgt is offline
Old 12-23-2007, 10:54 AM
  #204
motodude11
motodude11's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yup here are the close ups and yes the body still fits on it too its like a handle with the body on now!! The bracket i made is out of aluminum L stock and on the other side i used the same back side mounting hole from the LST2, then i cut the front one off and made that mounting section flat with the roll bar, i then drilled and tapped a 4-40 hole though the chassis and mounting bracket and bolted that one towards the front of cut and shaved mounting bracket from the lst2. (the body is on a little crooked from the factory so the body on pic from behind looks a little funny sry)
ID:	832102   Click image for larger version
ID:	832103   Click image for larger version
ID:	832104   Click image for larger version
Old 12-26-2007, 01:29 PM
  #205
motodude11
motodude11's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Heres some pics with the new (ttr) st-1 side guards on Monsoon
Josh
ID:	834328   Click image for larger version
ID:	834329   Click image for larger version
Old 12-26-2007, 01:35 PM
  #206
vnmsgt
vnmsgt's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
NICE! Did you have to make your own holes in the sideguards to match up with the frame or did it just bolt on? How much were the sideguards too?
vnmsgt is offline
Old 12-26-2007, 01:56 PM
  #207
motodude11
motodude11's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the side guards are like $10 a pair on amain and as for the holes i had to shave down the mounting spot on the guard (they have little nut locker things on them) with a dremel and then i drilled out the front holes (in the chassis), I used the rear holes from the monsoon mounting spots and im not running bolts in the middle (its stiff enough already). You could drill the holes out on the guards i didnt think of that o well to late now and it already works!
Old 12-26-2007, 03:19 PM
  #208
sinfony78
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how's that pipe compare with the stock pipe?
sinfony78 is offline
Old 12-26-2007, 04:05 PM
  #209
motodude11
motodude11's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no idea lol, i haven't even had time to run it at all, i didnt run it with the original pipe either so i wouldnt know.
Old 12-28-2007, 05:04 PM
  #210
motodude11
motodude11's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
where do you guys have your engine low and high speed needles on the sh's? seems like this truck is gunna be insane after its broken in!!!
Old 12-28-2007, 05:50 PM
  #211
Chubbysdad
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is no real final spot on the adjustments. Your location will change your settings.
Chubbysdad is offline
Old 12-28-2007, 07:07 PM
  #212
twomanytoys
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There are sooo many different variables in settings that no 2 engines will be or can be set the same and run the same. Heat, cold, altitude, humidity etc... You start at base settings and tune from there. Just watch your temps while tuning to make sure it dont get too hot and you will be fine. And yes the sh engine is pretty insane.
twomanytoys is offline
Old 12-29-2007, 08:46 AM
  #213
vnmsgt
vnmsgt's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All 4 of the SH engines I have run at different settings then each other. Can't really go by that. You can only really go off the stock setting if you are having troubles and start over from there again on your tuning.
vnmsgt is offline
Old 12-29-2007, 08:50 AM
  #214
vnmsgt
vnmsgt's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, dennis I need to know if you have a monsoon fuel tank in stock. I hit the side of a 2x4 coming out of a turn last night after my monsoon slid up onto some pvc sideways and down the pipe into the wood and slammed the pipe into the fuel tank and cracked it. May need more because it also moved my motor over and binding up my clutch bell and spur gear.[:@][:@] And that was after my first lap[X(]
[:@][:@]I HATE PVC!!!!![:@]
vnmsgt is offline
Old 12-29-2007, 11:50 AM
  #215
motodude11
motodude11's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
boy im glad i have those side guards and the roll bar lol
Old 01-02-2008, 02:25 AM
  #216
bbb18c1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
after reading all these post, I want to pick me up a moonsoon too!
I have a couple of questions though...is the moonsoon much different that the earthquake? I already have an earthquake and if i swap the wheels from the moonsoon to the earthquake will it be much different? The moonsoon looks to me like the earthquake almost except lower and wider.
Can anyone measure their moonsoon for me (outside of wheel to outside of wheel) so I can see how much wider it is than the earthquake (the redcat website dosen't say how wide it is).
Also I was reading about changing it to 12t clutch bell ( I also saw a 11t bell on the site).....what is the tooth count on the stock clutchbell.
Correct me if I'm wrong, but the fewer the teeth, the more low end power it will have, but the top speed will be sacrificed. I count on the earthquake 10t and that has pretty good speed already. If I change it to the 12t, then the top speed should be be better right?
TIA
bbb18c1 is offline
Old 01-02-2008, 03:39 AM
  #217
triggeraa
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I believe the monsoon has longer arms/wider tires. You can install either 15mm or 30mm OFNA hub extenders to suit your needs. I have the Himoto Rancho Pro which is the same as the Earthquake. I ordered the ofna hub extenders, upgraded the stock servos to Hitec HS-645MG and installed a roto start backplate for use with the electric start. I also ordered the new 12T clutchbell from Redcat Racing as well as some blue aluminum upgrade parts from him as well.
triggeraa is offline
Old 01-02-2008, 07:14 AM
  #218
vnmsgt
vnmsgt's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Monsoon has longer upper and lower control arms and has a longer chassis front to rear. All the other trucks like the earthquake are based off of the buggy chassis which is shorter. Stock clutch bell is a 10 tooth
vnmsgt is offline
Old 01-02-2008, 01:54 PM
  #219
bbb18c1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hmmm....so the moonsoon is also also has the 10t clutch bell.
I'm pretty much sold on getting one now, but I'm not sure about the clutch bell yet.
Is it worth ~20$ to upgrade to the 12t to gain more top speed? I don't race, just go to the park and bash. Does it lose much low end (acceleration) with the 12t?
I like the snappiness(sp) of the earthquake and don't want to lose that on the moonsoon by upgrading to the 12t, but yet i would love to have better top speed..........dilemmas[sm=50_50.gif].
thanks for the input everybody!
bbb18c1 is offline
Old 01-10-2008, 07:54 PM
  #220
vnmsgt
vnmsgt's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you are just bashing the 10 tooth will be perfect. The 12 tooth does give you a little more top end but mainly makes the car easier to drive and control in the air on a track for racing.
BTW I finally got my monsoon back together. I ran sideways into a 2x4 and hit the pipe into the gas tank and cracked it in half! Still have not been able to get my brake upgrade I did dialed in yet because of the tank broken but hopefully will get it done this weekend. It has so much braking that it will flip itself over and do a 360 forward if I tap the brakes over a jump and brings the rear wheels up in the air going into a turn. Too much brake to handle.
vnmsgt is offline
Old 01-12-2008, 07:08 PM
  #221
motodude11
motodude11's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
alright guys got it running it runs great went out did a little bashing awesome and super fast i just have one problem. The radio seems to glitch aot and kick my fail safe on. [:@] No fun when im running and the break goes on. But I cant figure out why its doing this I just switched from my futaba radio (worked fine no problems with same fail safe) to the redcat Digital FM radio and now its just glitchs a ton!!! Any tips and tricks to reduce the interfernce in these trucks is helpful!!! Thanks
Josh
Old 01-12-2008, 08:11 PM
  #222
triggeraa
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check for full charge on all batteries. Also check receiver wire for damage. I would have kept the Futaba.
Old 01-12-2008, 08:31 PM
  #223
motodude11
motodude11's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i woulda but im using the reciever in my tmaxx 3.3 now and thanks i'll check over that. anymore adivse to reduce the interference.
Josh
Old 01-12-2008, 10:17 PM
  #224
vnmsgt
vnmsgt's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Make sure your cystals are tight in their place and not loose.
vnmsgt is offline
Old 01-12-2008, 10:24 PM
  #225
Redharris
Redharris's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just Purchased a Monsoon.Woot Woot!
I read in some thread (cant remember which one) that the 1/10 cars are comming with FM radios now. Is this true?. Does that mean that my Monsoon will be comming with FM as well?
Redharris is offline
Contact Us Archive Advertising Cookie Policy
