what's the problem???
remote won't work after 2 runs.
when i turn on power on vehcle, vehcle function as normal, sterling and throutle moves a little bit(normal), but after that when i turn on remote, it doesn't move again(should move a little bit again), whatever i turn sterling or throutle or brake,it doesn't move, fresh battery doesn't help. the power of the remote will on,and indicator on,just function doesn't work, please help!!!!
which is broken?
sry for my english
which is broken?
sry for my english
RE: what's the problem???
if its less than 30 days old you can get a new radio from redcat for free, i would suggest buying a new system, you can get a complete futaba setup for >$50, futaba 2ph. Check towerhobbies.com unless one of the dealers on the forum sells them. The radio systems in the redcats or any rtr, especially the china made ones are not the greatest and know to fail.
ORIGINAL: ehroof
also i am in canada, i don't know if redcat will asking me to mail it back or not. if they ask me to ship it back, i will just save the hassel and buy a new one ot fix it.
CA
so is it a bad remote? or just the crystal is dead? it does power on. can i just buy the crystal somewhere for 27.175hz???
finally i open up the receiver box to check, then i found some water around the box and some on crystal, so i clean it up and use a fan to let it dry, then it works like before, i was so careless that i went in to some water spot yesterday, that's the problem
anyway, thanks for all the advices.
wow, your lucky that the water didnt destroy it, usually it would just ruin the electrics not fool with it like that, anyways glad to see you got it working!!!
