what will fit
IA
what will fit
just wondering if what other piston and sleeves wil fit a sh .28 or do you have to use just the sh piston and sleeve. cause redcat is out and trying to get one for this weekend
TX
RE: what will fit
Ya need to use the SH piston and sleeve. The porting on the sleeve and block match for the engines timing. If you use something else that fits or looks like it might fit the porting maybe just enough different to throw off the timing and either burn up the engine or just not run period in which case either way you wasted alot of good money for no gain.
