Tornado BB
Tornado BB
I know these questions have prolly been asked before, but I'm kinda new to the nitro world and would appreciate any help!!
I own a Tornado BB, as a starter buggy. I would like to upgrade the tires or maybe go a little bigger. I'm having some issues keeping good traction on the track. Does anybody have any suggestions as to what tires would fit my buggy, I've heard Rustler wheels and tires would fit. Also I had to replace the spur gears in my transmission due to some small rocks getting into it and just smoking my gears and clutch bell. (I'll for-warn everybody, small rocks do serious damage, LOL) Now I cannot get my buggy to shift into second gear, I'm certain the buggy quit shifting immediately following the break in period. I believe I have replaced everything correctly, because the buggy rolls freely in neutral and drives great. Don't really need second gear, but hey its fun to have. My main concern right now is getting the buggy set-up a little hire and grabbing some better traction. Anybody have any ideas........
Thanks for the help
Wolv.
Thanks for the help
Wolv.
RE: Tornado BB
i used rustler rears and hole shot tires
http://www2.towerhobbies.com/cgi-bin...?&I=LXFHL9&P=7
http://www2.towerhobbies.com/cgi-bin...p?&I=LXJJ86&P=
RE: Tornado BB
i use the stock rims and panther step pins for rear but i dont know for the front.I have pictures of the tires in my gally and my car is taller in the back. http://www2.towerhobbies.com/cgi-bin...?&I=LXNPP5&P=7
RE: Tornado BB
did the rustler wheels give you more of a stance, and widen up you frame a bit? Bisically I'd like a little more tread on the ground and a little bit taller stance. Also do that How bad will I throw of my gear ratio?
RE: Tornado BB
As for the shifting if you have everything set up correctly there is a chance that you might need to adjust the grub screw in the transmission. It sets the second gear kick to kick in at different RPMS the tighter that grub screw is pushed into the spring the longer it will take to shift and vice versa.
