clutch spring
KY
clutch spring
anybody know how do i place it back where it go's ,it popped out when i took my clutch bell off , but i did not see where it came from, ( tsunmia)
RE: clutch spring
There should be a groove on the outside of the shoes for the spring to go in. However, if it just popped off then it's probably broken. You can either get a Traxxas spring for it (4146x I think) or bend out the last coil of the spring out to from a loop to hook the other end of the spring on.
KY
RE: clutch spring
does the spring go completely around the clutch shoes in the grove and hook to each other, one end of the spring to the other?
