Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Fitting the paper
Old 11-08-2007, 06:45 PM
shoota0075
Default Fitting the paper
Okay, when I installed my clutch bell, how tight should the top screw be, very tight or just snugg? Which way do I pull the paper out, when setting the gear mesh? Or, how can I pull the paper out if it is trapped between the two gears?
Old 11-08-2007, 06:50 PM
ehroof
Default RE: Fitting the paper
the clutch bell screw should be tight, there should be a little play between the clutch bell and the spur gears, the paper is used to gauge the mesh not to set it, you should be able to pull the paper thru WITHOUT tearing it.
