Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
bearings in an hpi bell
Old 11-19-2007, 04:40 PM
biggbronco
biggbronco's Avatar
Default bearings in an hpi bell
okay, i got the hpi clutch bell and the two pinion gears for my tornado. when i put the 2 bearings in the new bell i can't get it all tightened down. the bell will slide back and forth a little. did i miss something here? i put the bearings in the new bell just like they came out of the old bell, one in the top, one in the bottom.
Old 11-19-2007, 04:46 PM
ehroof
Default RE: bearings in an hpi bell
did you put the washers in
Old 11-19-2007, 04:48 PM
biggbronco
biggbronco's Avatar
i put the washers in the way they came out of the old one. all i had was a washer and a lock washer on the end where the screw is. that same set up works fine if i put the old bell back on.
Old 11-19-2007, 05:09 PM
ehroof
what bell did you get?
Old 11-19-2007, 05:12 PM
biggbronco
biggbronco's Avatar
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCLR2
Old 11-19-2007, 05:15 PM
ehroof
that should be a direct swap, make sure there isnt a washer stuck in the old bell.
Old 11-19-2007, 05:19 PM
biggbronco
biggbronco's Avatar
there is a "lip" in the old, it looks like it's all one piece though
Old 11-19-2007, 05:21 PM
ehroof
you may need to add a washer or put washers in differnt places, maybe take the big one from the top and put on the bottom to bring the bell out a little more, how much play are you talking about, very little? there's no wobble in it right, just a little front to back play.
Old 11-19-2007, 05:22 PM
biggbronco
biggbronco's Avatar
no wobble at all, just front to back, lemme try moving the washer...
wait a minute, the only washer i have can only go one place, it isn't big enough to fit over the black shaft that goes thru the bearings. and here i thought i'd have this buggy out tonight [&o]
i guess i need to get some washers that'll fit over the shaft.
Old 11-19-2007, 06:27 PM
wolverine330
that washer left over is prolly the one that goes in the end, where your screw goes. Its big enough for the screw to fit thru. I put the same one in my buggy, and thats the same washer I left out, when I realized I had play. Even when I added that washer I had some minor back and forth play in it, but still ran very well, and I've had no problems with it.
Wolv.
Old 11-19-2007, 06:34 PM
ehroof
a little play is ok, just not excessive. here's a picture of how it should go:
Old 11-19-2007, 06:45 PM
biggbronco
biggbronco's Avatar
according to that picture i do not have 1, 5, and 6. they all appear to be the same size. i didnt have those in the original bell. where would one find those size washers? maybe radio shack???
Old 11-19-2007, 06:47 PM
ehroof
yeah or home depot. i know redcat changed their clutch bells a little while ago to all steel, they may be different now then before.
Old 11-19-2007, 06:49 PM
wolverine330
hardware store,.....maybe a true value or ace hardware.....anywhere with nuts and bolts man...
Wolv.
Old 11-19-2007, 06:57 PM
biggbronco
biggbronco's Avatar
okay that's a no for the Home Depot, i got some that are small enough but the hole in the middle is too small to fit over the shaft. i'm losing my patience, i drove an hour to another Hobbytown to get my new bearings and I still can't run because nothing is fitting right!!!![:@][:@][:@][:@][:@][:@]
Old 11-19-2007, 06:58 PM
ehroof
auto parts store, sorry bro
Old 11-24-2007, 01:39 PM
biggbronco
biggbronco's Avatar
SUCCESSS!!! I got my bag of HPI 5x10x.5 spacers (washers) today. I added a total of three to the clutch bell and placed them in various places between the bearings. Now i have the bell sitting PERFECT! I took it out to try it and WOW! I can really tell a difference! I mean it's probably a combo of the header, pipe, motor saver filter, clutch spring, bell and pinion gears, but man this thing moves now! I have RCU to thank for me learning all this stuff. Now if they could just get some good stuff out for the avalanche...
