Stall speed?
Stall speed?
How would i make the stall speed on the clutch in my tsunami higher? Since i put those stampede wheels/tires on it could use a little higher stall to take off harder.
also, if it seems kinda sluggish on the low end, but really rips up top, should i adjust the low speed needle?
RE: Stall speed?
use the traxxas 4146x spring or get this hpi setup, its an adjustable clutch and you can cut it and adjust the stall rate: http://www3.towerhobbies.com/cgi-bin...&I=LXLW03&P=ML
RE: Stall speed?
yes, you cant use the shoes that come with the 4146x, just the spring, the shoes are too small, actually, you may like the shoes, they give a higher stall, may be what your actually looking for, try them out and see what you think.
