If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 251 to 275 of 300
  1. #251
    Join Date
    Sep 2008
    tooele, UT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: "OFFICIAL" Redcat Avalanche thread
    Could anyone tell me the dimensions of the Stock TIRE from the avalanche? Just the tire i dont need the wheels dimensions.
    PBS style Redcat Lightning
  2. #252
    Join Date
    Sep 2008
    tooele, UT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Also how would the center diff hold up against either axial .28 spec 1s or HPI K4.6 (.28)?
  3. #253
    Join Date
    Dec 2007
    Richibucto, NB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have an Avalance that wont start at first i thought it was the clients cheap 18 V drill starter but no I guess it wasnt the drill starter.I removed the engine and checked for cracks in the piston,checked the one way bearing,cleaned the carb and everything seems to be fine but it wont start and if it does it stalls almost right away,fresh plug,fresh charge on the glow ignitor.I reinstalled the pullstarter and one thing i notice is that it cranks over really easy.alot easier than when it was new.Any help what to do next?
  4. #254
    rclynx's Avatar
    Join Date
    Sep 2006
    Modesto, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sounds like its engine time or the OWB is still slipping a bit. The low compression all but seals the bad engine idea []
    For those interested in the Avalanche that a customer cannot afford to claim PM me.
    It has over $500 in mods
    290cc fuel tank
    MX3S TX RX
    Hitec steering servo
    airtronics brake / throttle servo
    Sure start ele starting system
    rear exhaust system
    hardened steel steering link
    new Chassis etc. [:-]
    Custom Cars bring out the stars / Home of the RCLYNX, RC IMPROVEMENT, MOD, SALES & SERVICE Dealer;XTM, CEN, HPI & much more
  5. #255
    Join Date
    Feb 2009
    Glendale, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
    Are the tires series 40 on this truck? If not what are they?
  6. #256
    Join Date
    Mar 2010
    Washington court house, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
    Yes love those yellow wheels!!! What kind are those tire and wheel combo!!!!!  I keep beaking those chrome one from Redcat!!!!!Give a name and a number if you can.
  7. #257
    Join Date
    Sep 2009
    Debary, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
    Just from looking, they appear to be 1/2" offset "Truggy" wheels (1/8 scale 17mm hex) with 40 series monster truck tires..
    Mick Nesevitch
  8. #258
    Join Date
    Jan 2010
    , BARBADOS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    I'm wondering if a 'regular' clutch bell could be used in the Avalanche instead of the elongated clutch bell. I've asked this same question about the Monsoon, as Mick would know , and was educated to the fact that Redcat had changed the spur/clutch bell combo for the Monsoon.
  9. #259
    Join Date
    Sep 2009
    Debary, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    Do you have an Avalanch to check out Wolf?? A standard clutchbell will bolt onto the motor, but you may have to dremel the main shaft, to shorten it, or use something as a large spacer to take up the extra length of the output shaft.. Only other thing that prevents you from using a standard bell, is moving the motor forward so the bell/pinion-gear lines up with the spur gear.. Have to see the motor mount on an Avalanch to know if it'll accomodate the motor moving forward or not.. Might need to make some new holes in the chassis for the motor mounts as well.. It's pretty straight forward stuff, just need the clutchbell to line up with the spur.. Good luck bud!!
    Mick Nesevitch
  10. #260
    Join Date
    Jan 2010
    , BARBADOS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    Mick, I know I say this alot, but thanks again. Truth is, I'm just weighing my options right now about what to buy. Honestly though, it's between the Hurricane or Monsoon. However, it will most likely be the Hurricane since my girlfriend prefers buggies, and I am rather inclined to them myself . The reason I asked about the Monsoon and Avalanche is for the purpose of further reference, so that I can prepare myself for later RC purchases . The second vehicle would grace our possession as a basher, and I have this sneaky suspicion that the Monsoon may just take that place. However, it might be nice to eventually own all three .
  11. #261
    Join Date
    Jul 2009
    , QC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
    ORIGINAL: rclynx
    I have a fix for the steering plate [8D]
    It's my second steering plate and it's bent again (on a small jump this time)...
    Can you show me your fix?
    Tx
  12. #262
    Join Date
    Sep 2009
    Debary, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
    Hey McWolf!! Just now seen your post.. It's my pleasure! I like to help out as much as I can!! If I was you I'd definitely get something from the XTR line.. The "ultralight" series stuff there sellin is looking more and more like "toy" grade RC, from what Im readin.. I know the Monsoon (and Hurricane) are good, solid RC's!
    Mick Nesevitch
  13. #263
    Join Date
    Jan 2010
    , BARBADOS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    Hey Mick, I agree. The more that I read about the Ultralight series, the less I am inclined to purchase it. I still have to wait a while to build some funds but I am quite sure that I'll be heading the Professional series route. Also, are the shocks on the XTR series 16mm? Speaking of which, have you been out with the Monsoon recently?
  14. #264
    Join Date
    Mar 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
    Just wondering My Avalanche was running great and it just stopped!!!!!I tried to restart it fires and would run for a few seconds and die!!!!just found bearing out at the clutch bell!!!!!! thought this was the problem!!!!!! started with new glow plug, fresh fuel new lines,compression good ,piston crank ok!!!!! just will not run!!!!!! Been thinking  of electric!!!!!!!!!any answers!!!!
  15. #265
    Join Date
    Jul 2009
    , QC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    ORIGINAL: GerardAtJob
    ORIGINAL: rclynx
    Tx
    No one know the fix?? If yes please tell me!
    Ty all!
  16. #266
    Join Date
    Jul 2009
    , QC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    finally I'll make a full steel one...
    It won't bend again...
  17. #267
    Join Date
    Mar 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
    Has anyone else had trouble burning up the 2 bearings in the clutchbell !!!!!! and is there any upgraded bearings!!!!!!
  18. #268
    Join Date
    Jul 2009
    , QC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    ORIGINAL: 73bronco
    If you want better clutchbell bearings, just go grab a set of sealed LOSI or TA one (~10-15$ for 4). They are the same.. just bring one at your local hubby. I used the sealed bearings and it's x10 better than thoses from Redcat...
    And, sry for my bad english, but what do you mean by "burning" the bearings?
    Seeya bronco!
    EDIT: If you want more, search Internet for metric 5*11*4 bearings... Redcat "11*5*4" = "5*11*4" for every other company... don't really know why...
    Thoses would work no1 : www.vxb.com/page/bearings/PROD/Kit7598 and it would kick ass.
    EDIT2: Even thoses could work nicely... but I'm sure you don't want to spend 100$ per bearing lol www.vxb.com/page/bearings/PROD/Kit7405
  19. #269
    Join Date
    Jul 2009
    , QC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    And another question : I heard that the Monsoon got a full front upgrade, which works a way lot better than the older monsoon, but the Avalanche haven't... Is it possible to see an upgrade like this for the Avalanche? If yes I would buy a complete front to replace mine... (Or could the new steering system of the monsoon could fit in my Avalanche?)
    ty.
  20. #270
    Join Date
    Mar 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    Thank you for the info!!!!! I'm fairly new to the nitro side oft his hobby but love it! the only trouble i found with Redcat is getting parts~~~~~but i did hook up with Kurt out of New York(URC) and he has been great to deal with!!!!
    What i mean by burning the bearings is burning them up !!!!
    Bronco
  21. #271
    Join Date
    Jul 2009
    , QC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    lol then I burned a few of them... my first clutchbell still have pieces of my 3rd redcat bearing set stuck inside... impossible to remove lol
  22. #272
    Join Date
    Oct 2009
    Kyle, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
    I have an Avalanche and about 3/4 gallon, the truck at idle wanted to start moving as before it didn't. Took out engine and dis-assembled clutch bell and found that a clutch shoe broke (not the spring) and was grabbing the bell, also the two bearing were shot, one (outer part) was wedged in the bell housing, luckly the kit had all new parts. I'm down to about 1.5 gallons and noticed the clutch bell assy is loose/wobbly. I would asume the bearings again are on their way out. I'm going w/ some aftermarket brand or something that will hold up. The truck is a pretty good truck, minus the servos, they went out fast.
  23. #273
    Join Date
    Mar 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE:
    How do you adjust the brakes on an Avalanche!!!!!!!!!!!!ad where do you put the differential fluid????????? Manual is crap for this truck!!!!!!
  24. #274
    Join Date
    Jul 2009
    , QC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    Is they're a kind of special glowplug for theses?
    My first one just passed out, so I got 2 new from my LHS... and guess what... 1 start each and they're both gone...
    They're O.S. Glow Plug medium no8...
    Any help is welcome.
    And for your brakes, check your brakes rod (the 2 little rod that pull the thing that brake lol), you'll see a black thing on each rod's end with a small allen nut...
    For your differential fluid, just open it up. They're no other way around.
  25. #275
    Join Date
    Jul 2009
    , QC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: RE:
    Forget this... I found why...
    And BTW this truck is for sell... 150bucks. PM me.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
