Air Filter leak
AZ
Air Filter leak
Has anybody had one? My motor just got ruined today and there is only about 8 tanks in her. I think the air filter was faulty allowing particles to be induced by the engine. I dont even drive it in dusty places, as a matter of fact, I have only had the truck for 4 days now. I broke it in properly and have only had it in the dirt once. I was tuning it today and made a full throttle pass, as the r's got up the motor went "POP"!!! It was running real rich too!! So after looking at it and findind that there was no compresion, I knew it was toast. I pulled the air filter off and the venturi has dirt all around and even the snorkel from the air filter had lots of debris in it. This means that particles were passing somehow through the filter or there is a leak somewhere that I cant locate. This really sucks because the truck is so new and because of faulty parts my truck is parked!! I hope Redcat will replace the motor because there was no negligence done on my part. Hopefully someone from Redcat can help me soon.... [:@]
RE: Air Filter leak
I can't figure how dirt would get in there if the filter was on correctly! Because i have never ran into that problem. Sure you didn't swap out glow plugs while the head was dirty and some may have fallen in the sleeve? Didn't run with the filter off at all?
IA
RE: Air Filter leak
My guess is that the was a gap between the element and the housing of the stock filter, I know when I oil or clean my filter I pay close attention to make sure and tuck the ends of the element down into its seat. Perhaps it was an oversite on your behalf or maybe it was jarred out of place while you were driving it... either way sorry to hear about your trouble
AZ
RE: Air Filter leak
To answer all of you, I am not dumb or new to this so read what I said a little more careful. It is the stock air filter the truck is an avalanche. No there was no gap betweeen the element and housing and the head is not and has not been dirty so no, there was no debris that fell in while changing plugs.
FL
RE: Air Filter leak
Hey man, sorry to hear about your engine getting trashed. I think your looking for an answer that no one can give you. Somewhere, somehow debris entered the engine system...it happens.
IA
RE: Air Filter leak
ORIGINAL: cheeba400
Hey bro, calm down a hair, nobody is trying to insult you... This is just what we do as a group trying to figure out the how, what or why. If nothing else simply to have something to do over the winter months.... (like me) So please understand after reading your post I simply made an educated guess at the most likely senario since this would be the first case I've heard of a stock air filter failure on a redcat.
AZ
RE: Air Filter leak
GBI: that is one thing I didn't check so thanks for the insight. After inspecting the slide boot, it looks to be functioning properly and there is no gap on it or anything.
Bash: sorry if it seemed I came off mad it was not directed towards you. I am just really frustrated with the truck right now since all I have had with it is problems and it doesn't help that I have only owned the truck for a few days now...
RE: Air Filter leak
i really love my avalanche, it sucks your having problems with it, i have blown a few engines in my time, air filters falling off when jumping or on rough terrain. Breaking is part of the hobby though, always has been and will be. maybe take some pictures of the filter and maybe we can figure something out, pics of the entire filter.
MI
RE: Air Filter leak
Hey one more idea, have you taken the back plate off to see if the crank is broken. I just talked with a buddy of mine and he had a similar occurance with one of his motors.
RE: Air Filter leak
He said the venturi had dirt on it so that would rule out the backplate. I have been using teh stock filter with no problems at all. I also check it before every run. Clean everytime.
NJ
RE: Air Filter leak
I agree. Ther POP is a sure sign something let go,. Ill bet it had nothing to do with the dirt..
ORIGINAL: {GBI}Harryball
MI
RE: Air Filter leak
ORIGINAL: cheeba400
That could be. Hopefully. Incase Redcat won't warranty it, where is a good place to get another engine?
RE: Air Filter leak
ORIGINAL: cheeba400
