Hurricane XP Pro
Hurricane XP Pro
HURRICANE XP PRO... New In January...
These looks like lots of fun however just need to iron out its little problems... I have found a couple of issues after the running in period of the engine that might be of interest to most...
1/ Front top steering Knuckles screws are only held in there by 2 to 3 threads and seem to strip the thread out of the knuckle... You might want to upgrade them by putting in a longer screw (3 to 4mm)...
2/ The New Optional Parts available on the box... Mind got supplied with the New chrome plated wheel rims.. After the run in period they all had hair line cracks around the centre nut area.. after 2 tanks 2 of the wheels have cracked right through in a couple of places.. Don't Recomend these wheels at all...
3/ Keep an eye on the Rear Lower suspension hinge pin set surclips... Mind keep coming off...
4/ Watch out for the Upper Rear Reinforcement link screws.. Mind keep coming out...
5/ At the exhaust bend melts your body shell unless it's placed correctly... Same with the exhaust tip on the splash guard...
I've emailed Redcat Racing with my findings however would like to think they will come to the party on upgarding these poorly constructed rims that were supplied with aluminium ones rims and tyres.... I'm happy to pay the difference...
Does anyones else have similar problems or have other little ironing out problems on there Hurricane XP Pro I haven't found out yet???
Cheers Phoody
This car looks like serious fun 4 all!!!
Cheers Phoody
RE: Hurricane XP Pro
i have older hurricane xp's and the stock rims are fine, i dont really have any problems with them. as far as the other problems, i have had no problems either of my 2 hurricane's.
RI
I only just got through the break-in runs with mine, so take this with a grain of salt...
I haven't noticed any of the problems you listed except MAYBE the rims. Granted I smacked a curb with the right front and it broke up pretty bad, the front left I nudged and it only cracked. I have tons of CA glue and accelerator hanging around so I remedied the problem to get me through the break in and ordered up a couple of sets of tires/rims. problem solved.
And yes, I'm a newb and wasted the rims during break in...
your right about the upper arm screws in the hubs...one side stripped out ..I ran a long bolt though it and double nutted it at the top to get me by till parts come...I got proline wabash wheels on mine cause one broke...I like them better anyways...
Thanks so far guys...
The car didn't come with the standard rims with the car... They came with the NEW Optional Parts Chrome rims like the ones on the box... A 6 double spoke style... Are the standard rims stronger?
Are we mean't to undo all screws and bolts and loctite them all to stop anything coming loose...
Cheers
Cheers
diff locktite the 4 screws holding down the motor mounts..and anything thats going into metal.... I bought some longer screws for my front upper arms today...even got a bigger hex hole..and bought a little longer motor mounts screws that are stronger and less likely to strip the head..bought twelve of each and a foot of allthread and some nuts to make the connection on upper arms were the 2 allum. pieces go together...all that for less then $3...
BC, CANADA
i dont think the redcat rims are very strong. i broke 1 hiting a curb and i wasent going that fast. and then i broke 2 more just driving the thing. one time i looked at it and it ws fine then i looked at it after drivin a while and i have 3 broken rims.[:@][:@] and redcat dosent have any in stock
here's a link to where i get my rims and tires for alot of my rc's, great prices too: http://search.ebay.com/_W0QQsassZsup...QQfsooZ1QQrdZ0
check out those buggy rim and tires
Yes Yes...
Replacing wheels are easy however I have had no response from Redcat Racing on if they are going to look after me with replacing a poorly designed Rims (Been 2 weeks)...
I've found there aluminium Rims for the Buggy, Has anyone tried these out yet? Are they any good?
I'am lost without my New Toy... Hurry up Redcat Racing!!!
Cheers guys
Cheers guys
CA
The alloy wheels are great and you can change tires without ruining the rims draw back is hard crashes though..........when they bend its almost impossible to straighten them out
Banned
ORIGINAL: Phoody
Yes Yes...
Cheers guys
Yes Yes...
Cheers guys
got em from exactcustoms.com
but these are for the BB 1/10th, there should be 1/8th rims in stock soon
Banned
ORIGINAL: CORR
I'm still jealous every time I see them shiny perty rims
Banned
LOL, It will happen very soon, theres a dirt bike/ ATV race track just up the road from me. So thats where the pics will be take once break in is finished
Now that's a different rim again... Did you get those with the car or are they aftermarket?
Looks like your have been haing fun with your car...
