14mm to 23mm hex
RE: 14mm to 23mm hex
Im pretty sure they will work the only thing im not sure of is the diameter of the shaft that goes through the rim but the 23mm hex goes on just like 12mm and 14mm as you can see from pic all you can do is try Im pretty sure they will work though
CA
they will work, i just did a quick check, i put the larger ones on my maxx so i had the stock, the 14mm stock will work on the redcats
Hey Eddie Take a guess what these back tires are
ORIGINAL: rclynx
Hey Eddie aren't the axles on the volcano smaller than the Maxx? I know the 603404 fit my Mammoths and thats a lot bigger axle [&:]
i just tried the hex out fast, i will check in a few minutes again,
are those stock volcano rims with those 30 series?
ORIGINAL: retard1322
will they fit on the tornado bb
http://www3.towerhobbies.com/cgi-bin...&P=SM&I=LXJGR4
the center is slightly larger than the redcat 12mm hex, the wheels may wobble, maybe you can figure out a way to take up the slack, its not much.
CA
Yea they are stock Volcano wheels and they fit real well, I was thinking the chrome ones would look good on the Tsunami with that low Profile tire and its only about a quarter of an inch taller
