SH .28 Backplate
SH .28 Backplate
What backplate will fit the .28 SH engine? (not rotostart) I want to replace the pullstart with a regular backplate and use a starter box.
FL
RE: SH .28 Backplate
ORIGINAL: TNIGS
just leave ur pull start on, then if somthin go's wrong with ur box u have a backup
I bought a sportwerks bumpstart backing plate for clermont hobby and it works perfect. Here is the link for it.
[link]http://www.clermontmotorsports.com/servlet/the-324/Back-plate/Detail[/link]
Ahhh..perfect. That is exactly what I need. Thanks
Almost forgot..is there anything special I need to do or watch out for when replacing the backplate? I thought I read somewhere to make sure the piston is TDC when removing it.
FL
ORIGINAL: CORR
ORIGINAL: vnmsgt
You cannot do that because the pullstart backing plate makes the motor sit up higher and then the flywheel is not low enough for a bumpbox. With the bumpstart backing plate it lowers the motor enough to use the flywheel.
ORIGINAL: TNIGS
Dont you have to grind off the small pin thats on the end of the crank shaft?
I would like to do That on my Monsoon.
I have heard a LOT of different things about Lowering the engine.(it works....it Doesnt work...it doesnt mesh up with the Tranny... there is no problem and it works great. ..etc)
How EXACTLY is it done? Any MODS or Parts required? Did I Miss a Post where someone did it (and posted pictures)?
I remember a Post by vnmsgt where he was asking the Same question as me. I Guess he Figured it out!
vnmsgt....Throw a bone to a brother! Help me out here.....
Thnx.....
Thnx.....
ORIGINAL: Clermont Hobby
yeah sprotwerks that is the one. No grinding.
I guess you dont have to grind off the small crank shaft *** as the new backplate has the channel for it to travel around in.
ORIGINAL: Redharris
Thnx.....
Thnx.....
AAHHH....... so you DO have to change up a few things.....I thought that might be the Case.
I just dont wanna have to RE-invent the Wheel, you know what im sayin?
If someone who has done this could explain the Process, I'd be Mightily Grateful....
And a Picture is worth a Thousand Words
I have been using that sportwerks peice for about 10 months on the SH.28. It has a groove so you do not need to grind the pin, it bolts right on. My partner uses the SH in a Mugen truggy works perfect. On the REDCATS you need to lower the motor by using just the motor mounts and not using the spacers that raise the motor up. I'm not sure you can eliminate the clutch bell that REDCAT uses as you would have to mount the motor closer to the front of the truggy and I don't think that is possible, REDCAT does make an 11 or 12 tooth clutch bell for the Monsoon and Avalanche. Hope that helps. I have 2 of the back plates in stock if clearmont is out
Sandman
VNV Hobby
ST Louis, MO
Sandman
VNV Hobby
ST Louis, MO
got sick of waiting. Still want to rebuild the SH28 however........Should have [link=http://www.amainhobbies.com/product_info.php/cPath/1_23_79/products_id/16332]this[/link] by the end of next week to put in my Monsoon.[sm=48_48.gif]
