Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
disapointment with sh .18
Old 02-05-2008, 06:31 PM
Shockdriver
Default disapointment with sh .18
i jut got my engine 3 days ago i put it in my shockwave with the volcanoe tires and it had trouble pulling then and today i puy the regular tires on it i was driving it trying to tune it and it locked up tearing up my new spur gear im highly peed off if you know what i mean.
and is i possible to have the clutch to close to the spur gear because i had it as close as it would go.
Old 02-05-2008, 06:35 PM
ehroof
Default RE: disapointment with sh .18
sure, it needs to be meshed correctly, if its too tight it will bind and strip the spur gear
Old 02-05-2008, 06:38 PM
ranger4x4
i did just what ehroof and clermont told me too and did the paper trick. same as the thickness of a hair, to get the mesh right. i've had my volcano chassis deep in hard snow. so hard the tires wouldn't spin in fact. but my spur is fine.
proper mesh is important.
Old 02-05-2008, 06:43 PM
TNIGS
ya u cant push it all they way. it will bind. thats just as bad as having it to far away or even worse
Shockdriver
how do i do the paper trick
Old 02-05-2008, 06:44 PM
Kemo
Insert a piece of paper in between the teeth of the gears. Get them close enough that you can pull the piece of paper through and you have it set after its tightened.
Proper mesh. There should be No holes where the gears have pierced the paper. The paper should be still fairly crease free as well.
TNIGS
oh and did u ut a smaller clutch bell on it. even with the better engine i would think that u would still need to go with a 13 tooth.
ehroof
you run a piece of paper between the spur and clutch bell, it should come out perforated but not torn, there should be a tiny bit of play between the gears.
Macanan
Macanan's Avatar
this is how you do it
Old 02-05-2008, 07:05 PM
Kemo
you've got 3 good pics to use as reference... let us know how it goes!
Old 02-05-2008, 07:19 PM
AffordableRC
If you have a 2 speeds transmission make sure that both gears are meshed correctly. It is possible to have it at an angle so one gear feels like its meshed fine and the other is too tight. The paper trick should prevent this but just double check. Make sure once you get it back together and meshed correctly that you feel the amount of play in the gears for future reference. Once you know what it should feel like then you wont need to hassle with the paper.
Old 02-05-2008, 07:26 PM
zeen420
Banned
ORIGINAL: AffordableRC
oh great... well gotta take the buggy apart again.....[&:][&:][&:]
Old 02-05-2008, 07:33 PM
twomanytoys
First off why are you trying to tune it when it has not been broken in yet?
Old 02-05-2008, 07:37 PM
Chubbysdad
did you gear the clutchbell down with the bigger tires? Just curious
Old 02-05-2008, 07:59 PM
Shockdriver
first off the engine was broken in i ran 5 tanks through it i took the trany apart and put i back togetther but i dont think its right could some one take a picture of a correctly put together trany. and i did not get the 13t bell for the car because i have the normal tires on right now.
Old 02-05-2008, 08:01 PM
Shockdriver
o and the paper trick worked
AffordableRC
From right to left in the picture it should go: bearing, shim, large spur, small spur, clutch assy, bearing.
Old 02-05-2008, 08:04 PM
p3t3v3x53
is that a hpi motor on ur truck? (the post showing the peice of paper). also ur sig says AMA what are u in it with? like motocross?
Old 02-05-2008, 08:29 PM
ehroof
ama stands for academy of model aironautics, you need it to fly rc planes
Old 02-05-2008, 08:35 PM
AffordableRC
ORIGINAL: ehroof
ama stands for academy of model aironautics, you need it to fly rc planes into people
Fixed
Old 02-05-2008, 08:41 PM
Shockdriver
I HAVE A SINGLE SPEED TRANY BUT THANKS ANYWAYS,
Old 02-05-2008, 09:04 PM
Kemo
you are welcome... thats the best I could come up with that could closely relate for ya.
Old 02-05-2008, 11:35 PM
hrdcoreglf
even with a single speed your motor can be racked. You need to check gear mesh and angle between the gears.
Old 02-06-2008, 11:45 PM
zeen420
Banned
How are you supposed to correctly mesh the 2speeds? iv'e tryed the paper trick and cant get the paper out in one peice, and if i manage to get it out in one peice, the mesh is way to loose..anyone else have this problem?
