servos messin up
AZ
servos messin up
ok so i ordered the direct drive from clermont and put it in and everthing, then the clip that help the gear in place came out so i had to retake it apart and put it back in, then i go out to drive it and the servos are being weird, when i stop sometimes the throttle doesnt want to go, i have to turn the wheels to get the throttle to move, then i took it inside and when i would turn the wheels the throttle servo would twitch and stuff. does anybody know what this would be, do i have to upgrade the servos or what.
AZ
RE: servos messin up
where are the crystals in the remote, i took it apart and couldnt find it, i heard its behind the wheels but i couldnt move the electronics over, the green part thing whatever its called
you will see a tag with the frequency on it, a small rectangle, has the number 06 or somting on it, maybe the numbers 27.***, its behind that, just push it in to make sure its snug and the crystal on the reciever.
BC, CANADA
this is 100% off this topic but i dont wanna make a new post. how to you make those messages underneeth what you type. IE. under ehroofs it says clermont......
AZ
ORIGINAL: TNIGS
AZ
ok i found the crystal in the reciever but not in the remote, where is it exactly. and no the batteries are not fresh, tomorrow after school ill check, today i had to go to school and then work right after that and then i had to workout right after work, and just got home, so no time today to work on it [] but ill check tomorrow. and how much are new servos? and where should i get them (link would be nice please) and should i buy a new remote?? do i have to buy a remote if i get new servos? or can i get one later after i get the servos??
BC, CANADA
th crystal in the remote it right in front of the wheel. it has a little sticker on it that says 27mhx. its a reclangular saped peace. you have to use a srewdriver to pry it out. yes you can change your servos without buying a new radio system
