1100 hump pack
TN
1100 hump pack
How long does it take to do a full charge on one of these, The 110 charger that came with it has a red light on it when its plugged in, does it turn off when charged ? or does it turn green when charged ? or is the light just to let you know there's power going to the charger, for some reason they don't come with instruction's
RE: 1100 hump pack
it depends, see how many mah the charger is, divide it into the packs mah and thats how many hours. Just dont let the pack get too hot or overcharged. most likely its a 7 hour charge
RE: 1100 hump pack
ORIGINAL: Macanan
okay the charger its self say's 100 mAh so that would mean it will take 11 hours to charge ?
That charger is safe to leave it on all day... it charges at such a low mAh rate that it wont even come close to hurting it.
TN
RE: 1100 hump pack
Looks like something that you would plug up when you go to bed, then it would be ready for the next day when you get up, lol but at the rate I drive it and repair and mod it, that wont happen to often
RE: 1100 hump pack
purchase one of these then use a quick charger
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWN:IT&ih=012
RE: 1100 hump pack
nope. mAh is basically the capacity of your battery pack. If your motor draws 1 Amp per hour, and you are using a 2500 mAh pack (2.5Ah), it'd take 2.5 hours for the battery to be completely drained.
RE: 1100 hump pack
ORIGINAL: Kemo
I think that what I just said right in simpler tems
Correct me if im wrong
RE: 1100 hump pack
not long enough LOL honestly i dont know i use the for awhile then just plug them in that way you always have enough charge its a real pain when you get the urge to drive get your car fueled up plug it the ignitor an pull it but it wont start OOPS forgot to charge ignitor well maybe tommorrow you know what I mean
BC, CANADA
RE: 1100 hump pack
ya but those blue aluminem meterd one. i think you can just slip the rechagable bat out and put in a regular c battery. im thinkin of geting one b/c i hate when the cheep one i have runs out of juice. with this one you could just slip another bat into it.
RE: 1100 hump pack
rechargeable cells will provide more starts than any alkaline will. Just get a few sub c cells and charge multiples overnight. Its always good to have at least 2 glow plug heaters/starters anyways, for just this reason.
