Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
High idle with brake on throttle back
Reply
Old 02-09-2008, 07:54 PM
Shindermouse
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default High idle with brake on throttle back
i have a redcat volcano 5v pro for some reason it idles extremely high when throttled back and brake on. linkage isnt hitting pull start handle. when observing carb it is not sticking in position. problem first started half way through a run. now it just idles high right off the bat. i tried adjusting idle to no avail. please help any suggestions apreciated.
Shindermouse is offline
Old 02-09-2008, 07:57 PM
vtrebel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: High idle with brake on throttle back
how big is your carb opening?
vtrebel is offline
Old 02-10-2008, 12:19 AM
Shindermouse
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the inside diameter is 8mm and the outside is 12mm
Old 02-10-2008, 12:44 AM
hummerman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My revo did that after breakin
had to richen up low needle to get idle right.
hummerman is offline
Old 02-10-2008, 12:50 PM
Shindermouse
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks i will give that a try
Old 02-10-2008, 12:52 PM
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Shindermouse
check and see if you idle is set to high for some reason, pull the air filter off and hit the brake and see where the car is set to, should be 1mm open,
if its a high/uneven sounding idle it could be your low end needle is too lean.
ehroof is offline
Old 02-10-2008, 03:01 PM
Shindermouse
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for your reply - throttle looks like it is open at least 2-3 mm - will adjust it. Also I have been told gas is only good for 3-4 weeks - is this true?
Old 02-10-2008, 03:13 PM
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no, fuel is good for alot longer if you keep it closed and in a cool, out of the sun place
ehroof is offline
Old 02-10-2008, 03:17 PM
Shindermouse
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thats good news about the fuel. Should have asked before - how do you adjust throttle to close the gap ?
Old 02-10-2008, 03:21 PM
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
idle screw, counterclockwise to lower the idle
ehroof is offline
Old 02-10-2008, 03:56 PM
Shindermouse
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for picture - looks exactly the same as mine. I have tried turning idle screw counterclockwise still runs fast - is their a way to close gap in throttle. Looks like it rotates inside carb and there is still a 2-3mm opening when throttle fully backed off.
Old 02-10-2008, 04:02 PM
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the trim knob on the radio may be set too high, its the small knob with th on top of it.
ehroof is offline
Old 02-10-2008, 04:14 PM
Shindermouse
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
have set trim and there is still gap 2-3 mm in carb. can this gap be reset? does it need to be dismantled? really appreciate your help
Old 02-10-2008, 04:49 PM
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
when you hit the brake, does it close? if not you have to turn the idle crew counterclockwise more.
ehroof is offline
Old 02-10-2008, 05:59 PM
Shindermouse
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It worked ! (turning idle screw counterclockwise to close gap) truck runs better than ever now. Thanks very much for your help. You made my son's and my day!
Old 02-10-2008, 06:00 PM
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
excellent bro, i am glad it worked out and i was able to help you, now go have some fun with your son.
ehroof is offline
Old 02-10-2008, 06:03 PM
Shockdriver
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how do you measure the gap in the carb
Shockdriver is offline
Old 02-10-2008, 06:06 PM
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
by eye
ehroof is offline
Old 02-10-2008, 08:40 PM
hummerman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ehroof,
Do the redcats have a stop so you if you unscrew the idle screw the slide wont close all the way?
my revo does and not sure if my redcat does or not?
Old 02-10-2008, 08:50 PM
ehroof
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no, it will close all the way.
ehroof is offline
Reply
Display Modes
