is it to cold
is it to cold
i wanna run my truck its 20 outside. my motor is brand new. never ran. you think i could start it let it run just to here it? and once it gets a little warmer then do breakin
RE: is it to cold
i suggest waiting but you can wrap the cooling head with tin foil and if you have a temp gun, try to keep the temps in the 200 degree range, its not good to break an engine in cold temps
RE: is it to cold
do it in your garage (dont forget to vent the exhaust somehow). i direct a spaceheater at the cooling head to warm it up and before i start and i make sure the temp is nice and cozy.
WI
RE: is it to cold
and i thought i was jonesing to run my truck. out the window? never thought of that. wisconsin is allful. 10 degrees and more snow than i know what to do with. what would the niegbors think with it running. lol
RE: is it to cold
ORIGINAL: dayglo
