Transmission (Diff) Help!
CO
OK...I've had the Volcano for about a year now, and the most frustrating thing in the world is working on the transmission (Middle Differential). I have an aluminum upper plate on and that seems to make it even harder. Does anyone have any tips on how to make this easier?
TX
RE: Transmission (Diff) Help!
ya, pull the engine and the rear end it amounts to about 8 total screws plus the 4 for the trans and it's out, takes about 5 minutes or less. also get a pair of forcepts to hold the drive shaft when you put it back together makes things so much easier.
CO
Right on! Thank you...I swear the transmission probably flies through the air more out of the truck than in!!!
CO
ORIGINAL: twomanytoys
What problems do you keep having wih the transmission.
