Redcat Servo horn wont fit Futaba servo
CA
Ok...
Im workin on my Volcano SV
Im replacing the Stock Steering servo with my Futaba 3003 servo.
The Teeth on the Redcat servo are more coarse (bigger and fewer) than the teeth on the Futaba servo.
The Redcat Servo arm will not fit on the Futaba Servo, (not without Forcing it anyway)
Now I've got to go to the LHS to buy a servo arm that will fit the Futaba and Match (size wise) the arm that was on the Volcano.
I've never heard anyone else complain about this before!
Am I On The Pipe, or What?
Anyone else use the Futaba 3003 servo? (It comes with the Futaba 3PM Radio)
CA
RE: Redcat Servo horn wont fit Futaba servo
Should still fit or work as long as the shaft is the same size. I have interchanged the different threads without any adverse problems..............just wouldn't do it to many times[&:]
Different brand servos have different shaft and spline sizes. If you use a futaba you need a futaba horn. Thats the way it is for all servos. Futaba, associated/ ace, hitec tamiya etc.. have different horns.
CA
Ahhh....That makes sense
Here I am,,,8itchin about Apples n Oranges not Tastin the same Huh? Lol...
I went out and bought a Futaba Horn. Lesson learned. Problem Solved..
BC, CANADA
1 Post
Weard becouse i have a s3003 and it fits perfactily! thow i had to push it on so... ya it will fit if you force it and will be beter becouse no play in the Horn so less chance of it striping... Catch my drift?
ORIGINAL: Redharris
Ok...
Ok...
i think we are both on the pipe.lol i bought a JR radio and servos and they didnt fit. The JR servos has a metal spindle thats why the stock horn wont fir. I just reamed out the hole on the horn a bit and it fits ok.
BC, CANADA
I found this a while back and it might be useful to others:
Number of splines for servo manufactures
23-spline:
Airtronics
JR
Sanwa
24-spline:
Hitec
Hobbico
25-spline:
Futaba
Traxxas
Blue Bird
Cirrus
FMA
TowerPro
MPI
23-spline:
Airtronics
JR
Sanwa
24-spline:
Hitec
Hobbico
25-spline:
Futaba
Traxxas
Blue Bird
Cirrus
FMA
TowerPro
MPI
Yep i had to change horns when i got my JR servos with my 1/10. But the JR works fine as a throttle servo with my 1/8. I dont think the splines are the same though cause the horn was pretty hard to push on there but it works.
CA
ORIGINAL: StephenW
when i got my 3305 (3003 w/ metal gears) it was in a nice little box and it had like 10 dif servo horns in it
Thats a Handy List bbb18c1.....Lol..wish I had seen it yesterday
With the JR i just used the long one it works fine. It came with a bunch of different ones though. I had to make the hole a little bigger so the linkage would go in though.
