Kuppler SV Battery cover screw.
ON, CANADA
Hey,
I have forced myself to overlook the fact that the rear screw on my Volcano battery cover binds with the spring on my rear shock. I can do this no longer and have to fix it. I am assuming this is a problem on most/all volcano's.
I noticed from some pics that Kuppler has fixed his. I am only assuming that he drilled a hole in the bottom corner of the case and the lid, ran a machine screw through and put a nut on the end.
It seems like the easiest fix........If anyone can think of a better way or the actual way kuppler did his i'd appreciate it.
Adam
Adam
NY
RE: Kuppler SV Battery cover screw.
I did the same thing. I also hot glued the screw inside the battery box so it won't slip around when I have the cover off. My glow wretch also fits the nut perfectly.
