If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 1 of 4 123 ... LastLast
Results 1 to 25 of 78
  1. #1
    Join Date
    Nov 2005
    listowel, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Got my Tornado going! ( short vid up )
    Well, Got to the LHS, Got all my stuff...minus the new spektrum dx2.0 ( didn't have it, but ordering it online), Think I got everything correct..Tryed to start it once so far but I installed my fail-safe wrong I think and I had no throttle control, So I removed it and it worked, Tryed again and the thing was just started to scream! scared to poop right outta me lol....Now I got no idea what the netural setting is for the idle screw, Bit of help?
    Edit, Went to try a second start, got it going but I had to keep the brake half way on for it to stop, Is this the idle screw?
  2. #2
    Join Date
    Dec 2007
    lewis, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Got my Tornado going!
    sounds like it....1 mm opening by looking in the throat of the carb...make sure ur radio is on when u set it...congrats on getting all ur stuff
    keep the shiney side up, the hammer down and the marshalls bored.....himoto rxb-1...himotoracingusa
  3. #3
    Join Date
    Dec 2007
    lewis, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    also make sure ur fuel trim is set to normal on your transmitter also
  4. #4
    5lagd's Avatar
    Join Date
    Oct 2007
    guelph, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    http://www.greathobbies.com/producti...od_id=SPM20200 spektrum DX2 from a canadian supplier bro. How does it sound, are you addicted to the sound n smell yet????
    carb opening pic ............
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    P4d4, Sl4sh & Vaterra Kemora
  5. #5
    Join Date
    Nov 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Alright, well.. I got thru one tank and having bit of troubles tuning it, gettin frustrated.. gunna wait till tomorrow
  6. #6
    Join Date
    Feb 2006
    howard beach, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    you dont tune on your first tank of fuel. you break it in first then you tune. You need to set the high needle to 2 1/2 out on the low, flush with the colar around it. make sure your idle is set up so there is a 1-2mm gap opening on the carb so it will idle.
    125 characters and 2 lines is not enough to list my RC obsession!!!
  7. #7
    Join Date
    Nov 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Alright, I got a 1500mah hump pack, How long should this take to charge? it says no where..
  8. #8
    Join Date
    Feb 2006
    howard beach, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    it depends on the charger, a decent way to judge is divide the mah of the pack by the mah of the charger, if the charger is 100mah and the pack is 1500 then its about 10 hours.
  9. #9
    Join Date
    Nov 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ok, got my 4th tank in, But everytime I hit the brake it stalls out?
  10. #10
    Join Date
    Nov 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, tryed to figure it out, and I can't.. 6th tank and it ran away on me, bent the shock tower.... not much..
    No idea what im doing
    Still stalls when I hit the brakes, and I cant even get it over half throttle or it boggs out and stalls, tryed screwin with the trim and thats not helping... I dont know.. starting to think that nitro wasn't for me [:'(]
    Edit: Also had to splice my hump pack wires because the connections didn't fit
  11. #11
    Join Date
    Feb 2008
    , BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ok for the stalling part, that means its to lean. richin the high speed a half or full turn out. i had the same probelm. now for the stalling problem, when you adjust your idle, push the break all the way and then ajust it. 100 bux says its closing the carb when your puting the break on. then if you car is idling to fast then your in nuteral(no break and no gas) then ajust you linkage on the reciver and if that not enof then you have to ajust in on the car. hope this helps
  12. #12
    Join Date
    Nov 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: jumpanddrop
    Ok, Now, Do I do this with the car on or off?
    Edit: Whats a netural setting for the idle screw? its all messed up
  13. #13
    Join Date
    Feb 2008
    , BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ok sorry i miss spelled that. im saying that first you ajust the idle so when the break is on it idles corectly, then when you relese the break and the motor revs up, this means your linkage is ajusted wong. then you can ajust it with the transmitter or you might have to ajust it on the car. you do this with the car on so youo know if the car is idling correctly
  14. #14
    Join Date
    Nov 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Alright, I think I have that problem solved with it cutting up when I hit the brake...
    Now... I'm done my break in, Starting to tune it.. I still don't know what is a neutral setting for the idle screw is, Because that would help alot! And, I can't get it half throttle without it bogging out, But I was told thats the high speed adjustment, correct?
    Other then that, Today was alright! I can't get the smell of the nitro fumes off of me, But I kinda like it
    And... WOWWWW!!! That thing is stupid fast LOL, Not even hitting second gear and shes flyin!
    Did a couple donuts and I got going to fast that it almost jumped off the ground and did the floppy chicken lol
  15. #15
    Join Date
    Feb 2008
    , BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ok the reson its bogging is its to lean. im am 99.9% sure of that. richin it up a good half turn. i know that break in setings are 2.5 turns out but i have fuly tuned my tornado and it likes to be 3 turns out.
  16. #16
    Join Date
    Feb 2008
    , BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    and there is no nuteral setting fot the idle screw. i was trying to say before the test out the car in nuteral( as like noo gas on the transmitter and no break, in between. when you pull the break, the gap in the carb should be the same as when you let the trigger go. if its not and the throtle is opening more then you need to adjust your linkage.
  17. #17
    Join Date
    Nov 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ok, I'm going to have to wait untill tomorrow anyways, I got the gap thing and linkages figured out, But there is no kinda of a neutral setting for the idle screw???, Kinda weird....like either its all the way in, or all the way out, or sitting in the centre.. I dunno, I'm tired LOL..this ain't even making sense to me any more [&:][&:]..Tomorrow will be a new day
  18. #18
    Join Date
    Feb 2008
    , BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hu, sounds like its stripped..... its should screw in and out just like the high and low needle. it shouldent push in or out. if it is stripped then you should get a new motor or at least a new carb from who ever u bought it from since its so new
  19. #19
    Join Date
    Nov 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    No, not stipped, worded that wrong sorry, LOL..I'll get a short vid a some pics of what my settings are at and do a vid of a couple runs..do that tomorrow..
    Odering my new radio, rims/tires, throttle return spring, and a few other little things tomorrow aswell
  20. #20
    Join Date
    Feb 2008
    , BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: zeen420
    sweet, did you get the 2ch or 3ch one???. i also thinkthat they have a deal on right now, buy one reciver get on free. i would do that so you have three recivers then the radio will be good for all your trucks. im looking at buying that 3ch spectrum. i like that one b/c it has a 4 modle memery and will be good if i buy a truck with reverse
  21. #21
    Join Date
    Nov 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm not to sure on getting the spektrum yet, I seen Idgasp's JR and think I might just go with that for now.
    LHS better have them, lol.. I can bring my buggy this time Id
  22. #22
    5lagd's Avatar
    Join Date
    Oct 2007
    guelph, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: zeen420
    i wont be have another saturday off for 3 weeks. boohoo. my JR radio was $109 i think.
  23. #23
    Join Date
    Nov 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: ldgasp
    ORIGINAL: zeen420
    Thats a bummer man, thats not a bad price at all,
    I did get the buggy out today to burn off the tank I had in there since the weather man "says" were getting snow [], It was pretty cold out but I figured that I fixed the problem with when I brake it cuts off the engine, But I guess not..... Now is there a screw that adjust that opening...or... is it adjusted by the linkage on the car its self and the trim?
  24. #24
    5lagd's Avatar
    Join Date
    Oct 2007
    guelph, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: zeen420
    ORIGINAL: ldgasp
    ORIGINAL: zeen420
    put on the brakes without the car running and look down the carb. is it completely closed? if it is screw (i think) the black screw under the aircleaner in untill you see the carb open up to 1-2 mm. let mw know if i am right on this guys?
    I am having problems with my buggy shifting so i think i am going to convert it to a single speed. less hastle.
  25. #25
    Join Date
    Nov 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ok, well If that screw is the thing that opens up that hole then I think mines busted [&:], If i screw it in all the way it will slightly open around 2mm but it will stick at full trottle if I go counter clockwise it ( all the way out) it does nothing.......
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
