wont be runnin for a while
well i new it was goin to happen but i didint get the failsafe in time. i hit a jump and pined the thotle to get my nose up and my reciver switch got nocked off[:@]. so there i am running as fast as i can accros the yard while it dose a could flips,smokes a tree and then tumbles into the gargen fence wide open[:'(]. i broke the gas tank, 3 A arms, broke the peace that the arms go into the chassis on the back, bent 2 shocks, bent my chasis and im almost 100% sure i blew up my motor. when i try to turn ther flywheel it just makes a clicking sound so i gess i snaped a con rod and wrecked a sleave. man this teaches me to put a return spring on. i gess its going to be a month or two before i can run again b/c i cant afford a new motor[].[:@]. anyone out there wanna give me a good deal on a motor??? [8D]
BC, CANADA
1 Post
RE: wont be runnin for a while
ORIGINAL: jumpanddrop
well i new it was goin to happen but i didint get the failsafe in time. i hit a jump and pined the thotle to get my nose up and my reciver switch got nocked off[:@]. so there i am running as fast as i can accros the yard while it dose a could flips,smokes a tree and then tumbles into the gargen fence wide open[:'(]. i broke the gas tank, 3 A arms, broke the peace that the arms go into the chassis on the back, bent 2 shocks, bent my chasis and im almost 100% sure i blew up my motor. when i try to turn ther flywheel it just makes a clicking sound so i gess i snaped a con rod and wrecked a sleave. man this teaches me to put a return spring on. i gess its going to be a month or two before i can run again.[:@]. anyone out there wanna give me a good deal on a motor??? [8D]
make a list of what parts you broke! and open up the engine i want to see what happened (and take pics of cource) and take pics of your whole ride!
dude that SUCKS [&o]
and that makes me want to get a throtal return spring!
i wish i could use the program but its not a redcat engine[:@]. gess ill have to start savin up for a new motor[]. i shouldent have gotton rid of the vx.18
ya i gess ill try and take the engine apart. kinda nervos doing that but i gess i cant wreck anyting. anything i should watch out for with these little engines??? hope fully its just a con rod,pison and sleave so i dont have to drop 120 bux on a new motor[:@]
BC, CANADA
1 Post
the only thing is, when you are takeing it apart take out the glow plug first then remove the head then the sleeve then the back plate then the conecting rod then the clutch and fly wheel then remove the crank. check it all for scratches. and if the conecting rod is gone might as while buy a new engine... what engine do you have?
RI
Nothing to it... Take the backplate and head off, if your conrod isn't in pieces use the ziptie in the port trick to help pop the sleeve off. Conrod/piston comes off the crank just about TDC (with some gentle coaxing).
There's my Readers Digest Abridged Version...
ORIGINAL: retard1322
BC, CANADA
1 Post
OOH Crap that sucks a hpi G3.0! that is a good engine! ya definitaly get a OS or get a SH
and can i have your old engine! see if i can fix it?
lol Canada to Canada... well BC to BC Cheep shiping!
TN
lol maybe if i can find i new one, might be a while tho[]
do you have a redcat engine
If you got an upgraded motor through redcat it will only cost you half the cost of the motor
Redcat Racing has one of the best engine replacement programs in the industry.
For as long as you own your vehicle, Redcat will replace your engine no matter what happens to it. Burn it up, wear it out or beat it with a sledge hammer, Redcat will replace it for same or upgraded motor for only 1/2 of the retail price of the replacement motor you want to buy.
BC, CANADA
1 Post
lol EBAY... even better Craigs list!!!
BC, CANADA
1 Post
lol ya ill give it a try. i just order all my parts and it just over 40 bux.[:@] i hate crashes. im going to order a retrun spring also. now i just have to find a good price on a engine. hopefully i can win a half decent one on ebay for 60 bux. maybe ill try that sniping thing
insted of buying a throtal return spring online (for 2 or 3$ highway robery) go down to rona or Home depo take your rc with you and go to the springs and choose one there it is about 50 Cents for one there!
BC, CANADA
1 Post
Ya the only thing is take your rc with you and choose a spring that will pull the servo back then the reciver is off but not to mutch that the serco boggs and is rilly slow... so get a light spring but one that will pull it back
and glad i could help!
BC, CANADA
1 Post
ya the throtal return springs are more reliable than fail safes... if your falesafe has a batterie (witch i doubt) it will be ok, but if the power is cut to the fail safe you are screwed! but throtal return springs are a wonder i am going to get one tomoro when i go to my bilders suply
