Fuel tank issue...
BC, CANADA
1 Post
Fuel tank issue...
hey
i have a problam...
when i am ever trying to prime my car useing the Plug and Pull method (lol just thought of it P and P lol) i try and prime it and it turnes over and i can feel air comeing out of the pipe and the fuel is not moveing... it worked perficatly fine befor but not it does not want to work... and i do have a fuel filter and i checked it and it is clean and no dabree in it... so i have no idea what is going on... i got mad at the car when i was trying to get it primed, i literaly thought of Chucking it agenst the wall!
so i hope you can help me...
thanks
-cam-
i have a problam...
thanks
-cam-
RE: Fuel tank issue...
ORIGINAL: retard1322
hey
i have a problam...
thanks
-cam-
hey
i have a problam...
thanks
-cam-
ok, well double check the fuel tank for an air leak.. you may wanna pull the tank out and water check it by blowing into it while its under the water..just take the tank submerse it in water, plug up the feed tube and blow through the backpressure tube which hooks to the exhaust and see if you have any air bubbles coming from the tank..if you get alittle from the fuel cap then replace the 0-ring on it..and while blowing air through see if the tank bubble from any part of the tank..
andy
andy
BC, CANADA
1 Post
ok i will try it and ya i am runing a tornado and this is my new tank i am runing and my old one was cracked too... i will try that... thanks
and if it is that i am breaking out ither the epoxy or Seal-all! Becouse this tank i am runing is my new tank... but then i blow on the vent toob the fuel does not move then lertches and flows agan! Weard...
BC, CANADA
1 Post
ORIGINAL: Lordmik
Might be some leftover stuff from making the tank in one of the nipples.
ya i will try and blow some air from a compressor in the fuel toob from carb to tank and give it some air and see if it makes stuff blow out...
BC, CANADA
1 Post
ORIGINAL: Lordmik
You'd be surprised how much crap gets left behind during manufacturing. Not just on these rc car parts, but on anything.
BC, CANADA
1 Post
ok i tryed all of that and it flows freely like there is no resentance but assoon as i put to tube on the carb it stops and does the same thing... and i alredy pulled off the carb and cleaned it all to make sure there was no gunk and it is all clean and no dabree... so i have no idea of what is going on...
go with a new carb, my buddy rc danny had a problem with his, put a carb that i had laying around from an os .12 cz and it worked flawlessly. get a new vx carb
BC, CANADA
1 Post
eeh i need a whole new engine so i might as well get a whole new engine! i took the manifold off and spun the crank to TDC and there was a leeking noise and i could see bubles out from around the sleeve... so i think the sleeve or piston is shot so i need a whole new engine... and i was thinking of geting a engine on Craigslist... i dont know if you guys know it... but it is like ebay with out the bidding and no shiping you go and pick it up and you can get some steller deals on it!
redcat engine replacement program...............
BC, CANADA
1 Post
ORIGINAL: ldgasp
so that is out of the question! so i will just get a os or a Hpi G3.0...
AZ
You have this option too. and you can use the stuff from your old engine. if it matches up. if you have the 1 1/4in pullstart then you are golden
