Need help Please
SC
Need help Please
Ok im starting to run ma buggy again, and it sat becuase of winter. Now the only problem im having is when i hit the breaks to stop my engine shuts off. Now what do i adjust, so when i hit the breaks the engine stays on???????????????????. Is it the throttle setting so air gets in the carb??
RE: Need help Please
sounds like you either have to raise you idle, turn the idle screw clockwise so the carb stops closing or you have a broken clutch spring, if it starts on the ground then its most likely your idle, whats happening is when you hit the brakes, the carb is closing.
