low speed needle
low speed needle
I went to the redcatracing.com to see the tuning tips for the low needle.Now what i don't get for what there saying do a few runs to get temp up pinch the fuel line if dies in 3 seconds to lean but if dies in 4-5 seconds or longer to rich so what is it i hear different ways to adjust the low so what is the right way
RE: low speed needle
But basically this is a simply a good guide to know if you're in the right ballpark. It helps you know if your engine is running crap because of the HSN setting, or the LSN setting, or the idle gap setting.
AB, CANADA
harley75 it`s up to you to listen to me but what I do is I adjust everything till I see smoke, on idle it will be hard to see but what I do is make sure I see smoke and have good take off speed. If it bogs it`s too rich(but make sure you don`t lean out too much you need smoke). I`ve tuned all 3 of my redcats that way and they run incredible.
