volcano sv break-in question
RE: volcano sv break-in question
also do you perform the break in with the hsn and the lsn in position the factory set it to, and then do you tune it after the break-in process??
AB, CANADA
I think all of your questions were answered in the other post you made http://www.rcuniverse.com/forum/m_7564581/tm.htm
CT
http://rcvehicles.about.com/od/nitro.../f/breakin.htm thats what i used it worked good i tried the one above for one of my last cars and its doesnt run right at all i dont think it broke in right cause that one is not very specific on what to do
Whatever break-in procedure you so, make sure the piston is at
BDC (bottom dead center) when cooling down. I marked my flywheel
so all I have to do is flip the car over and turn the engine until I see the
mark. Or you can pull the glow plug and watch the piston.
Chris
Chris
