how do i remove owb from SH28
RE: how do i remove owb from SH28
when i pull off the roto start plate all i see is the starter shaft. the owb on the sh28 is internal. how would i clean an internal owb? and what else can i do to fix this issue
sorry forgot about that. You have to also remove the back plate and then you will find the OWB. Get some 120grit sandpaper and scratch up the pullstart shaft along its length, not around it. This give the OWB something to grip on to.
