Low speed needle
Low speed needle
If I turn the low end mixture screw counter-clockwise what does that do? I'm trying to cool down my motor and the needle valve is good with bue smoke out the exhaust. I just needed low end speed and my needle valve seems to be set good, just running hotter than it should. Let me know with any ideas that will give me low end and keep it cool. Thanks
RE: Low speed needle
counter clock wise will richin it...this will cool it but most likely will make it doggy on the low end if you go to far...your temps should be between 220 to 260...
ok, thanks for the info. I thought that was how it worked, just wanted to make sure before I went and started turning screws and got it all out of wack. Thanks again.
