Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Redcat Lightning Info!!!
Reply
Old 06-30-2008, 07:34 AM
r\c justin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Redcat Lightning Info!!!
Hey guy just wan't to ask whats tires and rims!! i order some drift tires from redcat hardest tires to put on yet took me like 2 hours to get them on!!! so i was looking at getting new rims and tires so i have a couple of pair. and whats the setting for the HSN and the LSN, after break in? i finally got my Volcano running and didn't have to buy any more parts maybe the luck is on my side now!!
r\c justin is offline
Old 06-30-2008, 10:04 AM
r\c justin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Redcat Lightning Info!!!
Just drove with the pvc in the middle of the tires the drift tires u buy from redcat totally impossible!! can't do anything but spin around in circles!! everyone have any answers i think i need a drift tire w\o the pvc
Old 06-30-2008, 02:30 PM
chevyderek72
chevyderek72's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
setting should be flush with the collar on the lsn and about 2 1/2 turns out on the hsn
chevyderek72 is offline
Old 06-30-2008, 04:09 PM
el_tonto
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
PVC is very slippery and best for electric. Nitro drifts better with slightly grippier tires, such as ABS or any of the "drift" tires from HPI, Yokomo (which tend to be ultrahard rubber, but not PVC).
The other thing to do is lock your diffs, especially the rear. Most recommend cleaning the grease out and packing with silly putty or something thick and pliable, which you can remove later if you choose. The extreme choice is JB Weld or similar, but that's a one-way trip!
Also, make sure you have no camber on any of your wheels, especially the rear (although as you drift, the tires will wear flat anyway).
Also, softer springs (and lighter oil) all round is a good idea. Hard springs will make the transition from grip to slip too suddenly, and you'll find you spin too easily. From what I understand the Lightning springs are very very hard compared to other brands.
And finally, throttle control! There are some very good drift lesson videos by HPI on youtube - begin [link=http://www.youtube.com/watch?v=1eBg_sSghx4]here, the lesson starts at about 1m30s[/link]
el_tonto is offline
Old 06-30-2008, 05:33 PM
r\c justin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have the abs tires from redcat, and i have a nitro lightning, it just seems to be to much, i think i am going to get some hpi tires!! and can i still drift with out locking my rear diff..
Old 06-30-2008, 06:12 PM
r\c justin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just order the 4402 from hpi with rims and front tires can't remember the part # hope there be here soon
Old 06-30-2008, 07:34 PM
el_tonto
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A locked diff doesn't help you break traction - and that clearly isn't the problem here - it helps maintain a better-controlled drift. Without a locked diff, one wheel invariably spins faster than the other. As the weight subtly shifts, the weight on each wheel and hence the grip varies and so you spin out. With a locked diff, even when the weight transfers from one side to the other, the amount of slip at the tires doesn't change because both inside and outside tire are slipping at the same speed. So better control.
el_tonto is offline
Old 06-30-2008, 07:48 PM
r\c justin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yea i checked out that vid u sent helped out i drifted a little bit , going to get some stick puddy tomorrow and try again
Old 07-01-2008, 07:30 AM
r\c justin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey guys anyone have the link to lock the diff, with stick puddy?
Old 07-01-2008, 11:07 PM
el_tonto
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Step 1 - open up and clean the grease out. (Remove as much as you can, but it's not critical to remove absolutely 100%):
Step 2 - fill with putty.
... that should be about all you need to know. p.s. those are actually wheely king diffs but the redcat ones are pretty much the same.
el_tonto is offline
Old 07-02-2008, 04:45 PM
r\c justin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks dunno yet if i going to lock the diff.. going to get my other tires and rims on there then go from there thanks alot for the pics!!
Reply
Display Modes
