I lost the "Shift Adjustment Screw"!
TX
My "Shift Adjustment Screw" seems to have worked itself loose and fallen out. Does anyone know where I can get a new one? This time I'll be sure to thread lock it... (its my cousins car, by the way)
RE: I lost the "Shift Adjustment Screw"!
you will most likely need the sping and the ball as well... contact Wade at allaboutfunhobbies he should be able to hook you up
your best off getting a 2 speed shifter, just put a dab of blue loctite on the grub screw to keep it in place better. its part number 02045 drive clutch
