Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
y are my glow plugs going out so fast?
Reply
Old 02-24-2009, 06:09 PM
cadillac98
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default y are my glow plugs going out so fast?
i dont think im running it too lean or anything...but it seems to go thru a glow plug after each rday of running now, sometimes going thur two in a day..it didnt used to be like this...what could be my problem?
cadillac98 is offline
Old 02-24-2009, 06:22 PM
1972roadrunner
1972roadrunner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: y are my glow plugs going out so fast?
what % of nitro fuel are you running? what's the heat range (hot, med, cold) of your plug? it might be too lean still.
i'm running Blue Thunder Sport 30% fuel with a racers edge cold plug (i forget the number). i burned my first cold plug up within the first tank. i reset my needles and set it a little rich, and it didn't burn up right away, so i tweaked it just a little leaner, and it's been in there for the last 3 or 4 outings.
oh yea, higher % nitro content requires a cold plug. lower % requires a hot plug.
1972roadrunner is offline
Old 02-24-2009, 07:04 PM
cadillac98
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
im using the premium fuel..its 20% nitro...and the last 3 plugs i went thru were medium...jus ordered two cold and 1 medium..i know my hsn is not too lean because there is a good amount of smoke trailing it..and this last outing i richened the low speed jus to be safe..
Old 02-24-2009, 07:06 PM
cadillac98
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
should i be using cold med or hot plugs since im using 20% nitro?
Old 02-24-2009, 07:31 PM
1972roadrunner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.maxxtraxxusa.com/Glow_Plu..._in_herre_.cfm
http://www.rc-truckncar-tuning.com/G...g-reading.html
i searched google with "which nitro glow plug" and those were in the first two or 3 on the list.
here's another one. http://www.scootworks.com/rdrc/gloplugs.html
Old 02-24-2009, 07:32 PM
chevyderek72
chevyderek72's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hot for 20%, how are they going bad, like how do you know?
chevyderek72 is offline
Old 02-24-2009, 07:42 PM
1972roadrunner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
for me it died and wouldn't start untill i changed it...
Old 02-24-2009, 08:08 PM
cadillac98
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
exactly..goes dead and i check the plug by taking it out and touching it to the ignitor..no light, not good
Old 02-24-2009, 08:26 PM
cadillac98
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
is there anything else u guys can think of that would cause the plugs to be going out so quick..i mean i had to change two today..they were medium tho, but still..i have used plugs for much longer than a half tank of gas..
another thing...the guy at rufaster.com said that the temp of the plug affects the performance/tune up kinda like the weather..warmer weather, leaner mix, etc...how does the plug affect it? should i expect to run leaner or richer since im moving from A medium to hot plug?
Old 02-24-2009, 11:56 PM
rjsdad
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
check out this site www.*********.org/cars_eng-tuning.htm According to this
higher air temp lean
lower air temp rich
higher humidity lean
lower humidity rich
higher barometric pressure rich
lower barometric pressure lean
higher altitude lean
lower altitude rich
higher nitro content rich
lower nitro content lean
higher oil content lean
lower oil content rich
hotter plug rich
colder plug lean
I hope this helped out.
rjsdad is offline
Old 02-25-2009, 07:57 AM
tri_county_racing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What type of plugs are you runningand where are you getting them? They should not burn out that quick!
tri_county_racing is offline
Old 02-25-2009, 01:29 PM
cadillac98
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i got a couple from hobby town and a couple from rufaster...i know two were os brand...but as long as there is smoke coming from the pipe i should be ok right..i mean i tune it where its not too much and not too little smoke...
Old 02-25-2009, 05:54 PM
rjsdad
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After break in period, I changed the glow plug and have been using the same one ever since. I am using a hot plug with 20% nitro fuel. I made sure that I tuned it as the web page I gave you told me to, and I is running fine.
rjsdad is offline
Old 02-26-2009, 01:00 AM
el_tonto
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Make sure your filter is clean and oiled (and installed!!!) maybe there's a bit too much cruft in there somewhere which conceivably could wear the plugs.
el_tonto is offline
Old 02-26-2009, 01:55 AM
cadillac98
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well i had to remove the cooling head to replace the head button..i guess this would be an ideal time to take the engine apart and clean the insides, especially since i stripped the head button...im sure shreds of metal are in there now...
Old 02-26-2009, 03:13 PM
el_tonto
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clean the engine bearings too while you're at it - can't hurt!
el_tonto is offline
Old 02-27-2009, 11:30 AM
cadillac98
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how much needs to be takin off to get a good cleaning job done inside
Old 02-27-2009, 12:12 PM
Encountr
Encountr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
remove backplate.
clean everything inside.
Encountr is offline
Reply
Display Modes
