transmitter?
AZ
RE: transmitter?
Anything is compatible if your talking about the radio system. If you just want a transmitter as in the radio, then any am radio will work. But if your getting a reciever and transmitter then anything will work
GA
RE: transmitter?
yup, i just had to buy a hitec radio, receiver, and servos. the were 75mhz am, so i had to switch em out, but if you want to keep the servos, the radio and receiver will work.
GA
RE: transmitter?
if you do upgrade, more than likely you'll have to make minute adjustment on the servo horn. i had to make a smidge adjustment on the horn for the idle to be set properly even though i had the throttle trim set to 0.
